JT cb antenna wire routing location
scotticus
Scott
SA, TX
2020 JT LE
Derpston
I used the Quadratec kit and ignored the instructions. Ran the coax along the outside of the engine compartment, behind the plastic corner shield, into the cabin by way of some handy foam at the corner of the windshield, then down through the panels, under the dash, to the center console.
Had to lower the windshield to do the routing but it's clean.
I did this the second time I ran an antenna wire. So much easier and cleaner.
WhatExit?
48th State
SargeDiesel
michael
Jeep Gladiator Rubicon Diesel
Retired Military
I'm familiar with that plug hole, it's the hole where the clutch pedal is supposed to be if you have an automatic, I was hoping someone was familiar with one somewhere on the passenger side.
you can remove the a pillar plastics/handle and fit it throught the weather striping and it will com out under the hood cowl and easily routed into the engine bay.... similar to a dash cam install.
look here:
