VA6489
- First Name
- Rob
- Nov 2, 2017
- 9
- 304
- 360
- Dahlgren Va
- Mercedes E250 Bluetec
- Build Thread
- Link
- Occupation
- DoD
You likely have the wrong shocks on your kit. if you only have 1.35 of droop at ride height you will blow the tops of the shock out. The leveling puck is doing you no favors either.I installed a 2.5" Clayton lift with an additional ¾" leveling puck to level the truck. The shocks provided are Fox 2.0 (FOX-985-24-177) with a listed maximum extended length of 26.35". While driving, the suspension feels fine on compression when hitting bumps, but on rebound it feels harsh, almost like the shock is topping out.
I measured the front shocks at ride height (eye-to-eye) and they are sitting at approximately 25". That only leaves about 1.35" of drop travel before full extension. From what I understand, this seems very limited and may be causing the harsh rebound I’m feeling. I also experience occasional death wobble on larger bumps, which I suspect may be related.
Does this amount of drop sound too short for the lift? If so, what shock extended length would be recommended without risking the coil springs unseating from the perches?
