No Initial start up after using a Battery Tender
abe57
George
Indiana
2021 Mojave
retired
2021 Mojave 3.6 auto .. Problem: after disconnecting the battery tender, Tender is Green fully charged, then trying to start the jeep it sounds like it tries to start ..Like it has a dead battery one initial hit . Cycle it off hit the brake and push the start button again same thing. Do this cycle for 5 to six times and then it will fire right up and start with-out any problems afterword . Playing with the tazer with it in the start mode with out running the engine hence the reason for the tender.. Can not figure this out. Do I need to let it set and cycle after entering the jeep B4 I hit the start button ?
dcmdon
I would unmary the tazer and remove. Then see if this continues. I t probably will, but it never hurts to exclude the tazer from the problem.
If this problem is easily repeatable, bring the truck to the dealer and bring the battery tender and show them the problem. This shouldn't be happening.
Lost1wing
West Georgia
Retired AMT
Playing with the Tazer? What settings did you change? Did you do the 2 reboots and a full sleep cycle? Were you having battery issues before you started playing with the Tazer?
abe57
abe57
George
Indiana
2021 Mojave
retired
No all is good now.This thing does not like to have just accessories on and not running for to long of a time. To many things are active and runs the battery down fairly fast .
