- First Name
- Bill
- Oct 12, 2019
- 247
- 40,445
- 53,880
- Runnells, Iowa
- Occupation
- Vehicle Showcase
- 3
Grill comes off in about 2 minutes with a small screwdriver or pocket knife to lift the top 6 retainers.I purchased and installed the Lasfit hood lock which doesn't interfere with your front trail cam, and you can't see the lock from the front at all. It locks and unlocks with the key fob using pneumatics. It works well and gives a piece of mind. I also have enabled the hood alarm via my taser. I'd recommend that you get the trim tool kit, just makes removing the grill & trim pieces easier.
Link below
Lasfit Stealth Anti-Theft Automatic Hood Lock System
Video
(22) Jeep Stealth Hood Lock for Jeep Wrangler JL Gladiator JT Key FOB Control -Install Guide - YouTube
I used my pocket knife to pop the centers up, then pulled the retainers out, and even with winch in the way, popped the grill off to run the plow wiring............... not a scratch on grill or the retainers on top.
For any interior trim - those are easily damaged unless you use the plastic trim tools (save for the piece under the steering column - you can pop that off with hands, no tools at all)
I like the idea of the Lasfit - but why pneumatics and not a system like a door lock motor? They work quickly and both directions and no pump needed. You can get them with some long strokes, or use a lever to increase the stroke distance.
I can't figure why they complicated it with an air system instead of a motor, maybe even a stepper motor.
