Shifting Issue into 4WD
CerOf
Dallas
‘21 JTRD
my experience in last 2 winters: on unplowed forest roads... shifting into 4H easy .. shifting into 4L works best in neutral.
To shift to 4lo it is ***a requirement*** that the transmission be in neutral.
TrailHiker
Denny
2020 Jeep Gladiator JT Sport S, Black 1946 CJ 2A
You are supposed to shift into neutral before shifting the transfer case to 4L, per the JT manual. I find shifting into 4H works best with engine in low RPMs, and coasting at 5-10 mph.
cheers.
Rocksalt
Illinois
2020 Jeep Gladiator Sport
cheers.
agreed with 4LO.. 4HI can be engaged up to 55mph as per owners manual and my experience
Blade1668
Darrell
N. AL.
I drive a gravel road and every week or so I shift in to 4 hi for a few miles and back to 2wd, first few times it was stiff shifting. Not so much now. I had the plastic connector on my XJ fail many years ago I just drilled the linkage on T-case and lacing wired it. That plastic clip I might want to pick up a spare after reading this while it's available. Hmm could be a interesting project for casting out of metal too.
domingjm
Fort Collins CO
2022 Gladiator Sport S, Diesel
So is there a consensus on the protocol for 4H and 4L when NOT moving? I was on some steep rocks today in 2H. Sand started giving way unexpectedly and my rear end was sliding left toward a ravine with no forward motion. It was getting pretty sketchy. I absolutely needed my front wheels, preferably in 4L. How do I get to 4L IMMEDIATELY from a stop in this situation? I'm not gonna lie, it was a little scary. I definitely should have researched this before going out there.
Edit: "consensus" is the wrong word, implying that opinions are relevant here. How does one get to 4L at a stop?
Summitsearcher
Northern Michigan
2021 Stingrey JTR
The same way, set E brake, place trans in neutral, place trans in drive and hope you don’t ? yourself in the process. The real answer the “Confucius” want to know is why did you wait so long to use 4WD?
domingjm
Fort Collins CO
Shitty driving technique.
NachoRuby
Chad
Pennsylvania
4hi - just shift it
4lo - Works for me if I put it in neutral for a second and then back in gear. But mine's Manual. Auto might be the same.
dcmdon
If you are going straight down the highway, shift it into gear for a few minutes then back out.
At highway speeds you will never be turning sharp enough to cause binding.
Mine goes in easily at any speed. Its a mechanical kind of movement. Not unlike shifting a steering column mounted shifter from park into drive on an old car.
dcmdon
Put it in 4H before you go off road.
or do what I did and get a truck with SelectTrac and leave it in 4H Auto almost all the time.
NachoRuby
Chad
Pennsylvania
He's got a diesel, so that's not an option. However, 4hi should easily shift, all the time, moving or not.
For 4Lo, usually I shift the transmission to neutral for a second, then back in gear, then shift the transfer case. It goes right in, even if I'm not moving, every time that way. I'm manual, but I think that would be the same, even on the Auto.
PlayfulBird
Germany
JT 2020 Rubicon Gobi
This nubbin part that is prone to breaking linked on the first page, does it make sense to carrry one of those as a spare?
If so does anyone have a part number and install instrructions?
Thank you so much.
As to the shifting in 4L, if I go over 3mph (i get up to 5mph shift it to N and then wait a second for speed to drop) it grinds like i shifted without a clutch (just a comparison it is an automatic).
Works fine though. Love the low range feel of the gladiator.
domingjm
Fort Collins CO
I don't think he was responding to my question.
