Wheel bearing squeaking?
j.o.y.ride
Foster City
20 Gladiator Overland
Recently in the mornings when the truck is cold I will get a squeaking from what sounds like a wheel bearing. It is on rotation of the tire, doesn't seem to be on steering. Seems to be from the front. Doesn't really sound like brake squeaks but I suppose it could be. Any way to check the bearings easily?
BamaJeepTruck
Reinhardt
Alabama
2020 Jeep Gladiator Sport S
Jack the truck up, push the wheel left to right, and top to bottom. Check for play. If there's play left to right it could be steering components, or the bearing, if there's play top to bottom thats a pretty good sign of a bad bearing. If there's no play I would put the truck on jack stands (a lift is always preferable, but most don't have access) and put it in 4 wheel drive and listen at each wheel as someone else gives it some gas. A whirring noise from the bearing would be what your listening for. I sure hope that helps.
Renegade
Zac
Signal Mountain, TN
2020 JT
Also watch for a rear wheel wobbling slightly as you roll down the road. Rear axle flanges can bend, causing brakes to squeak with tire rotation. I had this happen to mine. It was a good excuse to upgrade to Chromoly axle shafts.
j.o.y.ride
j.o.y.ride
Foster City
Oh and visual on the ball joints seems fine, no obvious tears or rust or dislodged.
chuckelb
Idaho
2020 Gladiator Overland
Any chance you ever figured out what it was? My 2020 gladiator is doing the same
coastiej171
Indiana
2021 Jeep Gladiator Sport
Check intermediate shaft bearing. Either take to dealer have them check it out or take off cover to the FAD. Original bushing is plastic and ends up failing a lot. Mine was replaced with a bronze or brass bushing…it progressively got worse for me to an almost grinding or tire rubbing noise
There's a TSB on the FAD area making noise.........
chuckelb
Idaho
Thanks. The dealership had it for a week and all they could come up with is "can't replicate the noise".
PW45
Phil
South Puget Sound
2021 Mojave
Dad, Veteran, Electrical Engineer
bump to top, I'm having the same issue. pretty sure it's coming from the front but I can't tell which side.
Does that FAD bearing make the same squeak noise?
vst
Scott
Tennessee
I have the same issue it’s on my driver side rear it’s the brake pad grabbing slightly. When I jack it up off the ground and spin the tire slow I can replicate it. Only happens after the truck has been sitting a little while and goes away after like 30 feet of driving. Now I have to see if it’s the caliper or a maybe bent axle but I think if it was an axle it would always make the sound but maybe not.
PW45
Phil
South Puget Sound
2021 Mojave
funny you posted that, I just took a guy from work in it and he was like, no way that's the bearing it sounds like brakes.
vst
Scott
Tennessee
I thought it was coming from the front also until I spun each wheel
PW45
Phil
South Puget Sound
2021 Mojave
well I got around to lifting each wheel one at a time and I could not recreate the sound. none of them had side to side or up/down wobble. I guess I'll just wait until it gets louder?
Although I'm at 66000 on the original brake pads so maybe...
