Aftermarket Diff Covers? Hype or Help?
Gray Matter Jeep
Rick
Middle America
2020 Jeep Gladiator
n/a
Do you Rock Crawl? Do you hit "big rock & rutted" trails with Wrangler Peeps?
I will be doing the Rubicon Trail later this year & am concerned about my stock Diff Covers...
Seems like the diff covers get tougher with every generation or Wrangler, thus less of a need to "upgrade".
What are your opinions on the Dana Rubicon diff covers we actually have?
Is replacing with an aftermarket cover really necessary?
Minty JL
Jeremy
Ft Meade, MD - AOR
My buddy added the AEV diff covers when he regeared......I'll probably do the same. They're beefy
hjdca
Southern California Mountains
I ran The Rubicon trail last year. Your rear diff will drag on rocks, and If you have to back up, or slip off a rock, you will hit the bottom of the front diff, and possibly your rear diff cover.. I had both Diff skids and nodular iron Diff covers (all Metalcloak).. My rear diff skid took lots of scratches.. In my opinion, if you have to economize, diff skids are more important than diff covers, but, you will not regret getting both diff skids and diff covers for the Rubicon trial.
Note: Your rear sway bar end links will also take a beating. I bent mine up at the Rubicon Trail again.... I switched to a rear RockJock anti-rock when I got back.
Jeep Gladiator Aftermarket Diff Covers? Hype or Help? sxgiGR
Jeep Gladiator Aftermarket Diff Covers? Hype or Help? O7o588
Jeep Gladiator Aftermarket Diff Covers? Hype or Help? X5DeCW
HappyGladiator
Matthew
La Verne Ca
2022 Gladiator Rubicon
Electrical tech
Sometimes i wonder if those heavy diff covers don't actually hold the heat in the oil.
Gray Matter Jeep
Gray Matter Jeep
Rick
Middle America
2020 Jeep Gladiator
n/a
I ran The Rubicon trail last year. Your rear diff will drag on rocks, and If you have to back up, or slip off a rock, you will hit the bottom of the front diff, and possibly your rear diff cover.. I had both Diff skids and modular iron Diff covers (all Metalcloak).. My rear diff skid took lots of scratches.. In my opinion, if you have to economize, diff skids are more important than diff covers, but, you will not regret getting both diff skids and diff covers for the Rubicon trial.
I had diff skids on my 2018 JKU on 35's, with oem diff covers.
I was thinking I would do the opposite so I don't lose any clearance. Not one fraction of an inch clearance loss.
jac04
CT
2021 Mojave, 2014 JKRX SWB
... And I wonder if that is why the Dana nodular iron diff covers have ribs - not only for strength, but maybe for a little extra heat dissipation. It's plausible I suppose.
I have the Dana diff covers. I've beat the hell out of them at Rausch Creek.
jac04
CT
Some people are willing to give up a little ground clearance so they won't get hung up. The tough part is that on the JL/JT you are giving up 1/4"+ of clearance because the slider goes completely under the diff housing. That doesn't sound like much, but every bit of clearance matters. Giving up 1/4" under the diff is like running tires that are 1/2" smaller on diameter.
The JL / JT diff housing design is absolutely horrible in terms of catching on rocks. The 'webs' on the bottom are like anchors when dragging them over rocks:
Jeep Gladiator Aftermarket Diff Covers? Hype or Help? 1674680166584-png
It's too bad that AEV doesn't make a diff slider that is similar to their JK version. On their JK version, the slider tucks up in front of the bottom rib, and you don't lose any clearance. I run that slider on my JKR:
Jeep Gladiator Aftermarket Diff Covers? Hype or Help? 1674682365331-png
Gray Matter Jeep
Gray Matter Jeep
Rick
Middle America
2020 Jeep Gladiator
n/a
Excellent points. Literally. ?
The main reason I am considering a slider is because of those two seams/edges on the rear you point out with red arrows.
Get diff skids instead. I have diff skids and factory covers. I’ve done the rubicon and other equally difficult trails. There isn’t a scratch on my covers or diff housing for that matter.
Thanks for posting this. I added a skid to the rear and was looking for a simple solution for the front.
That’s a design I haven’t seen. Looks cool. Roll bars for the diff. :)
Tackett1980
WVA
2021 JT overland
NP-C
I had a set of fulls on an h2 years ago when they offered them and they did a great job got beat up pretty good. Might get a set for the gladiator now that I know they have them. I forgot all about them until I saw this thread actually.
