GladiatorPilot23
So Cal
2023 Gladiator Rubicon Eco-Diesel
The sensor kit document on the first page shows up 2022, does that mean 2023+ don't have the issues with a different sensor?
Also, from what I have been reading, it's related to wear metals in the oil that the sensor miss reads? Is this still the case on the 2023+?
EDIT: After more research I found info on the Wrangler forums that the 2023+ Axles have this issue fixed as they are different design and won't fit the 2022- locker.
I was thinking to keep that Z locker tricker harness as a backup but won't be needing it.
Panther69
2021 Stingray Gladiator Mojave
So does this kit have fixed sensors or will you just end up having the same issues again after awhile?
RubiNewbCB
757, Coastal VA from the 810 Thumb of the Big Ol'
22 JTRD, 21JGCL, 07 Mustang GT, 05 Chebby Hoe, 90 Fox body stroked and poked393W
USN NSW Seabee (1994-2021Ret.) / Current status DoD PMC
Does anyone know why the kit has 5 sensors in it?. Im at the stealership and that kit has 5 sensors. Other than the front and rear sensors, where would the other 3 go? They're all identical and labeled 1-5. Do they actually expect them all to fail.
GypsyMech
Endel
AZ
MX Tech
I was told they are different strength sensors. Start with #1 and see if the light goes out, if not, seqentially change the sensor till the light goes out. Mine used #1, still have the other 4.
