Battery Replacement now no tunes
Jumpmaster 65
Eric
Lumberton, NC
2020 Gladiator and 2010 Wrangler
Yesterday I replaced both primary and Auxiliary batteries and now I have zero audio, even the Uconnect doesn't have audio
Any suggestions to get my audio working?
Lunentucker
2021 Jeep Gladiator Mojave
People Work?
If the screen is otherwise functional you can go to settings and try a soft reset.
If not then try turning the power on, but not running, push and hold the volume and tuning buttons simultaneously for 20 seconds to force a reset.
Most say it takes several sleep and drive cycles for these things to correct themselves after power loss like this.
Could be that it just needs a day or two.
JTR178
Goose Creek, SC
2020 Rubicon
UConnect kind of shits itself when it's disconnected from power. Give it a couple days.
JTenn
Middle Tennessee
20 JT Overland, 21 JT Willys
Mechanical Engineer
Yup, lost the HVAC for a day when I disconnected my batteries.
JTR178
Goose Creek, SC
2020 Rubicon
I lost that and the passenger heated seat which freaked me out because I'd just mounted a compressor under it and thought I'd broken a connection.
Moabite
Moab
2020 JT Rubicon
Replaced both of my batteries last week. I lost front and rear cameras for a couple of hours but everything else worked as soon as I restarted the Jeep. ESS had not worked (thankfully) for about 2 years, but it came back with the new batteries. I was surprised that I did not even lose my radio presets. As others have stated, wait a few hours and your UConnect may function again after it talks to the Mothership. I'd be surprised if it takes more than a day. But it probably wouldn't hurt to try the reset already mentioned.
Just curious, did you access the auxiliary battery through the fenderwell or from above? There's a much greater chance of messing something up if you access it from above. I have 35s and a Mopar lift and had plenty of room without even removing the tire/wheel. I pulled the whole fender in about 5 minutes...did not even need to remove the liner from the fender.
Jumpmaster 65
Jumpmaster 65
Eric
Lumberton, NC
I removed the front right tire, it wasn't bad.., I don't like where it at.
I'll give it a restart as previously stated.
A buddy told me my batteries went dead at the same because I disengage the start/stop feature too much and the Auxiliary bat can't recharge. What do y'all think about that
JTR178
Goose Creek, SC
2020 Rubicon
Aux battery charges regardless.
JTenn
Middle Tennessee
Mechanical Engineer
I hate when coincidental crap like that happens. Very frustrating. But the electronics on these things is my biggest worry.
Lost1wing
West Georgia
Retired AMT
That
A buddy told me my batteries went dead at the same beause I disengage the start/stop feature too much and the Auxiliary bat can't recharge. What do y'all think about that
[/QUbeOTE]
That would be an indication that your buddy is not a good reference to go to for the Jeep. Hey but he took a stab at it!
Short trips or not driving it often are the biggest problem for these. There is a constant drain on the batteries from the alarm, computers, and head unit. If it's not being driven regularly, a battery maintainer is recommended. Whether or not you allow the ESS to activate has no effect on charging.
rr11
Rick
Fl
2020 JT 2005 TJ 2003 F250
I put a battery maintainer on my truck in November, my auxiliary battery was always charging. I drive the truck every day but the battery would take 50 miles to be ready. The battery maintainer appears to have been a temporary fix. Now I need to decide if I replace the factory battery set up or go the dual battery route.
Casique
South Florida
2021 HA Gladiator, 2011 FLHX
Definitely will go with the dual battery set up when my warranty is over!
