Dilly’S Willy
- First Name
- D
- Nov 26, 2025
- 13
- 527
- 527
- Fucking, Austria
- 21 PBJ Gladiator Willys 6spd, 02 wrx wagon (stroker), 25 ZP 450E
- Build Thread
- Link
- Occupation
- Engineer/Business Owner
After searching here and the wrangler forums (maybe not good enough) I haven't found enough info to make an educated choice regarding when brake line extensions are needed, related to lift/tire size/full articulation WITH sways DISCONNECTED. Both front AND rear, seems most info is related to 38"+ and 3"+ lifts, but little mention about front vs rear, or what lift they have to support, or if they rub, or if they disconnect sways.
So for those who have:
- 35s
- Stock wheels/no spacers
- 2"+ lift
- Disconnected swaybars
- NEVER RUBS
...Do you need brake line extensions? How much longer? Will line long enough for FULL articulation on 37s work without interference on 35s?
This is info many can benefit from, and others can use as reference to other tire/lift setups and how long the lines need to be. Also please state what trim Gladiator you have too.
- 35s
- 2"+ lift
- NEVER RUBS
