EOC stage 2 and Exhaust installed. Now engine won't stay running!
rtjeepman
Derek
Northern Kentucky
2021 Jeep Gladiator Rubicon, 2017 Jeep Cherokee TH
Respiratory Therapist
I just finished my EOC stage 2 upgrade. I followed the video by Wolfoverland on YouTube. I did not disconnect any wires that were not covered in the video. The engine would start and run for about 2 seconds and then die. The dash showed "start/stop not available."
I either drained my battery by having the hood open for a couple of days. Or disconnected something that wasn't supposed to be. Or something may be wrong with my tune.
I only had about a half hour to mess with it before work today. I have not ran any codes with my Jscan. I currently have my battery on a charger and will try again in the morning after work.
Does anyone have ideas on what i could have done wrong?
Gregj
Greg
West Texas
2018 JLU, 2018 JLUR, 2023 JTuRD, 2017 JKRR
Sad to say you are going to have to send the ECU back, this happened to the second ECU I received, the first one had the security light on even though I sent the original in. Message EOC and ask them about it.
Gregj
rtjeepman
rtjeepman
Derek
Northern Kentucky
Gregj
Thanks for the info. I sent them an email and they wanted me to check a couple of disconnected wires and charge the battery first.
rtjeepman
rtjeepman
Derek
Northern Kentucky
I tried starting the truck again today and I can hear the fuel pump run but the starter doesn't engage and the dash shows "engine too cold to start" and "pre heat in progress."
NCJL
Dean
New Mexico
JLURD
Electrical
The Battery is where I would start.
DylanM
Dylan
'21 JTRD
USAF Retired
Just a thought, check your coolant temperature sensor and connector. If the connector isn't fully seated or the wiring is damaged, it may cause a false full cold signal to the PCM. The sensor is screwed into the front of the engine under the thermostat housing.
If you have a scanner or similar tool that allows live data to be shown, you could pull that up to see what temperature and other parameters the PCM is seeing.
rtjeepman
rtjeepman
Derek
Northern Kentucky
Thank you for the ideas and replies. Before work I deleted the auxiliary battery and put the main battery on the charger. I will check the coolant temp wire and try it again. My Jscan shows no codes.
Chance575
C
Earth
C
D
Verify the replacement computer has the right VIN with your jscan
rtjeepman
rtjeepman
Derek
Northern Kentucky
That's a great idea. Thank you. I had rechecked everything that I disconnected and made sure my battery was good, which didn't help. Then I swapped my original ECU back into truck a d it started right away and stayed running this time. I have to ship my ECU back to EOC to get it checked and hopefully fixed.
BlueScapegoat
Trevor
MN
91 ST185, 04 Ram SRT10, 04 Forester XT, SC'd 05 Rubi, 22 JTRD
Air Traffic Controller
Real pain in the ass if it's a VIN typo. Keep up updated.
rtjeepman
rtjeepman
Derek
Northern Kentucky
I finally received my ecu today. EOC said it was blank when they checked into the situation. Nobody knows why. This is the same ecu that I had cloned and then had EOC add the stage 1 tune. Somehow during the stage 2 upgrade, it became a blank ecu.
EOC was very pleasant to work with and they even paid for rush shipping to return the ecu to me.
The gladiator now runs perfect and im so happy to be driving it again. It really is unlike any other vehicle I've ever had.
Thanks for the input and advice from everyone.
Gregj
Greg
West Texas
Glad to hear you got it worked out. Some people say EOC is hard to deal with but that was not my experience with them.
Gregj
