FRONT overhead molle panel and soft-top?
crash3400
NWGA
2025 Rubicon X
Anyone using one of these with a soft-top? I've seen several posts about the rear molle panels, but only a few mentions of the front one that amount to "i got one". Most I've seen say "not for use with soft top", but for the life of me I can't figure out why. I've heard they can be a pain to install, but nothing about why they only work with hard tops. Ideas or experiences on why?
Jeep Gladiator FRONT overhead molle panel and soft-top? 41WC95BLH3L._SS135_
Brad.Clarkston
Brad
Kansas City
22 Gladiator Rubicon Sarge Green diesel
Sr. Network Eng.
I've got the Epic Adventure Outfitters Crow panel it would probably work fine with a soft-top tho I only have a hard top.
The way it's installed you have to pop out the rear sound bar and attach it to the frame bolts on the rear. The front has to be drilled and screwed into the cab frame.
All of the Amazon panels I've seen isn't half as sturdy as the Crow and you just 3M tape them on so yea you couldn't do that with a soft-top. It comes down to how you install the front two screws.
crash3400
crash3400
NWGA
2025 Rubicon X
i'm definitely not going to be installing anything with 3m tape! i can just imagine the whole thing coming down on me on a trail :facepalm:
Mrwoodmin
Tony
Vermont
Gladiator 2020
I have the exact one in my Glad, I love it. I have my CB mounted in it as well. Only down fall is it can be a head banger occasionally but then again Im 6' 2"
Zachattack50
Zach
West Michigan
2022 JT
Small business owner
I run one with a soft top no issues. I am using 3m because I didn't want to drill holes in my windshield header. I have had no issues. It just sits in the front and bolts in the rear, the worst it can do is rattle if the tape comes loose.
Bandit’s Lair
Southern California
2021 Gladiator Sport S
That double sided 3M is pretty good stuff. I use it for a lot of things. Currently have it holding down 2 300aH batteries in a rolling cart, a 3000w inverter on top of the cart, a couple power strips in different parts of the house where I didn’t want to drill holes in the wall. It holds and it doesn’t let go. Will it work on a trail? Has so far on my cameras that are outside of the Jeep. Don’t see why it wouldn’t hold up inside the Jeep unless heat got to be an issue with it.
Brad.Clarkston
Brad
Kansas City
Sr. Network Eng.
From what I've read online the 3M tape tends to rattle like mad once the tape hits a hot/cold cycle which would annoy the living heck out of me.
That's the main issue with 3M tape after a hot/cold cycle the front will rattle like mad. It can't fall because it's bolted in the rear but a low quality Chinesium might bend. My OCD wouldn't allow for that much noise so drilling is the only way.
crash3400
crash3400
NWGA
2025 Rubicon X
nice! that's that's what i'm looking to do. you've got 4" on me, so no worries there :)
crash3400
crash3400
NWGA
2025 Rubicon X
i know it holds stuff down with no issue. my concern is holding horizontally with added weight, heat, and jostling. may never have issues with it, but if the option is tape or bolt i'm gonna bolt every time
crash3400
crash3400
NWGA
2025 Rubicon X
fabulous. thanks! i've got both tops, so from what i can tell the clips for the freedom latches are the front bolt point. my key question was any issues with a soft top. problem solved!
AmosBurton
Amos
BC
2021 Mojave
This one I got from Amazon works perfectly with my soft top, bolted into factory holes on both ends. No drilling or tape required.
It needs the hard top mounting brackets to mount to which is why many people don't think it works with a soft top. I had to buy the brackets separately.
https://a.co/d/0ez0hLuJ
crash3400
crash3400
NWGA
2025 Rubicon X
just got mine and installed it last night. i noticed the same thing. kinda what i figured, but i thought i'd take a chance. it's not about the top, if you have the hard top latch mounts drilled - no drilling required!
