Empty Pockets
That explanation clears up things I’ve wondered about for years. It is clear and concise. Thanks!
Yes it is, very well explained too. I hope to find a cure for this one day and also a snappier throttle response that matches my brain/foot inputs too. I want to be connected to my 'go'.For those wondering, modern drive-by-wire manuals have rev hang programmed into them for emission reasons. The catalytic converter is only able to effectively do its job in a tight A/F range. Too lean = more CO2. Too rich = more NO2. The rev hang is programmed in so the engine doesn't experience a sudden rich environment every time you snap the throttle body closed during a shift. Unburnt fuel suddenly is without neccessary air to burn it efficiently and you end up with a brief rich environment. The 'hang' gives the engine time to fully burn that fuel.
Its annoying.
I look forward to trying this. I'm not up to speed on all this drive-by-wire stuff and appreciate all I've learned on this thread.I have a technique where I "tap" super fast ...
