Mohave X front coils fit 2023 Mohave 3.6?
Zephyr
Nick
Rhode Island
Mohave
Government
Attention Mohave owners - do the front coils for the MojaveX (Mopar #68607513AB) fit for 2020+ Mojave?
ArcticDreadnought
Thomas
Alaska
2024 JT/M
Oilfield Emergency Response
Benny, through the eldest magic, we call upon thee...
Grace us with your mighty knowledge, that we mayest be spared ignorance and break-downs.
Zephyr
Nick
Rhode Island
Mohave
Government
Have just located a couple of others who posted that they have successfully installed Mohave X coils on 2021+ Mohave. In addition, they have tow pack coils in rear and have installed aluminum spacers. They seem satisfied with the results.
Zephyr
Nick
Rhode Island
Mohave
Government
Interestingly, when I called MOPAR they explained that because Stelantis reuses to comment on interchangeability of model parts, MOPR could not tell me if the MojaveX front coils would fit the my 2023 Mojave
AllMoparParts.com
Summit Sponsor (Level 3)
Benny
New York
JT's!
Yes they can be used on any year Mojave.
Please let me know if you have any other questions at this time.
Thank you,
- Benny
ArcticDreadnought
Thomas
Alaska
2024 JT/M
Thank you,
- Benny
PRAISE THE BENNY!
*sprinkles motor oil and various snacks around the circle of transmission fluid*
Zephyr
Nick
Rhode Island
Mohave
Government
PRAISE THE BENNY!
Thank you M. Benny! I believe I was able to identify current MOPAR #s for these Max Tow shocks (awaiting shipment). Reading this and other threads, sounds like the 1 3/8" ICON spacers have worked well in conjunction with these coils - I've ordered them as well. Thanks to all who have patiently & helpfully weighed in!
Zephyr
Nick
Rhode Island
Mohave
Government
Thank you,
- Benny
Benny - can you please verify MOPAR Part #s for: 1) MAX TOW REAR RIGHT coil 2) MAX Tow REAR LEFT coil?
FLY-DOG
Kerry
Green Cove Springs, Florida
2025 Jeep Gladiator Mojave X - Bright White
Retired - USN 30 yrs + Delta Air Lines 22 yrs
When I bought my 2025 Mojave X, the "X" part was listed as "Customer Preferred Package 24A ($10,000) and lists a ton of extras, nothing related to the suspension....unless because that package includes steel front and rear bumpers (winch ready front), maybe the spring are different for that reason alone?
Jeep Gladiator Mohave X front coils fit 2023 Mohave 3.6? IMG_0693-1
Zachanadandy
Zach
Patterson, ca
2023 gladiator Mojave
Electrical foreman
Any JT front coil spring (or JLs for that matter) will fit the front of any other model JL or JT. The question is how much lift will you get going from a standard mojave spring to an X? How much lift do you want? This is why I prefer a coil spacer vs swapping different stock springs. You can't really tell how much lift you'll get. The spacers are cheaper and the same amount of labor to install and then you know exactly how much lift you'll get. It would suck if you want 1-1.5" and you spend the money and time to install the x springs only to find out you gained 3/8" and still want to add spacers and redo all the work.
Zachanadandy
Zach
Patterson, ca
Electrical foreman
They never break down spring part numbers or details on the window sticker. Most buyers wouldn't have a clue what it meant if they did.
Jaxmax
Jack
Bally, Pa.
Electrical Manager
It’s not for lifting it is a higher rated spring to carry winch and bumper weight and it gets out of the bump stops and gets shocks into in a better zone. A few have done it with good results , I am about to and also putting a 1/2” spacer in front and getting my spare Fox shocks refurbed and tuned a bit firmer in rear for weight of cap and fridge that is in all the time.
I’m one of the guys running Max Tow springs with Icon spacer in rear and also have the diff. shock too and am actually running skinner tires then factory and love the setup !…Jack
Wheelin98TJ
Devils Lake, MI
2021 Jeep Gladiator
Bean Counter
I'm surprised there are good results from this.
I wouldn't think the coil rate would be much different, not enough to matter.
