Snook55
- First Name
- Paul
- Aug 31, 2020
- 5
- 10
- 1
- Pittsburgh / Boulder
- 2020 Gladiator Rubicon
Hi everyone,
I'm looking for advice from the community on doing my first at home project on my truck. I want to make sure I'm not missing anything with respect to parts, safety tools, etc.
About the truck:
Like the title says, I'm a complete newbie so feel free to make any suggestions that you think I should know. No suggestion is too obvious.
Thanks in advance for your help.
About the truck:
- 2020 Rubicon
- ~48k miles
- 3.5" Rubicon Express lift kit
- Stock steering stabilizer
- Stock drag link
- Stock tie rod
- Clayton 3.5" HD Triple Rate Rear Coil Springs
- Teraflex rear trackbar
- 2 week old 37" Falken Wildpeak R/T
- These were a change from 35" Nitto Exo Grapplers
- The Jeep is off road on forest roads 4-6 days per week (for dog walks and hiking trail access)
- More serious off roading 2-5x per month
- Overlanding 1-2x per month
- Towing a 19' airstream flying cloud 1-2x per month for camping trips
I just had a shop install the Mopar Trailer Brake Controller in the truck and they charged me $385 for the install. I'm trying to avoid paying even more for the next set of upgrades/repairs I need to make.
(I suspect) Due to the new larger tires, constant / daily washboard road driving and frequent longer offroad driving I was getting a lot of wobble in my steering. While installing the trailer brake controller I asked the shop to look at the steering components. The tech tightened everything to spec but said I need to replace my drag link, tie rod, and (maybe) my steering stabilizer.
After I picked up the truck and took it for a test drive the tightening of all the components made a significant difference but did not fix everything. The truck still wobbles a little at ~38-46 MPH
Like I said, I'm trying to avoid paying too much for the shop to do the work for me so I'm considering doing the work myself. I've watched a lot of videos of installs for these parts and its seems straightforward enough. Although I have never done any work like this before, I figure I need to start somewhere.
I'm here looking for help and advice from anyone who has done this work to their own truck before to make sure I'm not missing anything.
Parts I plan to order (tell me if you disagree):- Metal Cloak Steering System
- https://metalcloak.com/jl-wrangler-jt-gladiator-hd-fox-steering-system-rubicon-edition.html
- I spent 3.5 months in Moab this spring and talked with many of the rental shops and tour guides around town. Many of them ran Metal Cloak components on their Jeeps and spoke very highly of them. I also spent some time this summer with a W.E. Rock champion who strictly ran teraflex. Thats the extent of my rational here... if they use it I figure I should. I'm looking for something bombproof that will last at least another 50k miles under similar or even harsher conditions
- [Question] What other brands, if any, should I be considering?
- [Question] Should I consider components with hyme joints instead of bushings? I am shying away from this because I had hyme joints on my front sway bar end links and within 8k miles they were knocking like crazy.
- [Question] Is the Fox steering stabilizer a good or bad choice?
- Ball Joint Separator:
- 1/2" drive Torque Wrench
- I dont need to jack up the truck at all for this project, right?
- Once these new parts are installed I'm going to have the shop do an alignment. Is this the right way to be thinking about the order of the process?
- The Rubicon Express front trackbar is adjustable and solid as can be. It also has not been adjusted after the jump from my very well worn 35" tires to the new 37" tiers. The shop will adjust this during their alignment, right?
