Question about Freedom Top color
Setec641A
Scooter
Maricopa, AZ
2025 JT Rubicon, 2018 JLUS
Earthling
Are the Freedom Top panels painted black, or are they molded in that color, and painted white underneath? Just curious if the White Cap top is painted or otherwise. I was thinking about the White Cap package, since a black top in Phoenix is asking for swamp-a$$. I was thinking, maybe just strip the paint off the top and expose the white, then coat it with some clear coat or protectant...
Bandit’s Lair
Southern California
2021 Gladiator Sport S
You’re going to want to paint it not just expose the fiberglass and clearcoat. It’ll last a lot longer with a good coating of automotive paint that can withstand the UV you get in Phoenix. It’ll look better too.
Y-Guy
E. Washington
2025 Gladiator Mojito! Mojave X
Might try a "wrap" on top.
One guy here left about 2" around the edges on his black cheap, and painted the center white, standing next to you don't see it but if you're up a bit you see it, but I could understood why he painted it like that - we live in the Desert too so gets warm... I just take my top off.
LoneWolfUSMC
Southern Indiana
2024 Gladiator Rubicon
I have considered this since we spend a good deal of time in the southwest. Just wondering how well it will hold up. I am not current on the options, but I have seen old vinyl that cracks and the adhesive destroyed the paint underneath from baking in the sun.
Y-Guy
E. Washington
@LoneWolfUSMC that could be, I'd talk to a good shop, I'd see the vinyl as a temp move to see if it makes much difference before going through the paint prep and expense.
LoneWolfUSMC
Southern Indiana
I was also considering white or light gray truck bed liner. It would likely be the most durable and easy to touch up.
Setec641A
Setec641A
Scooter
Maricopa, AZ
Earthling
That's a great idea, too! I hadn't thought about bed liner. I did consider Koolseal, as an option.
Sandman 4x4
Kissimmee, Florida
2024 Gladiator Sport S
Retired. Beach bum.
Yea living in central Florida with a heart wave is more than enough, especially when your Jeep has a black Freedom Top. Oh it’s great to take the panels out, in the winter, but under the sun? My roof gets so hot the AC must run on MAX to cool down, or constantly on recycle with AC split between dash and floor, with handy vents open in the rear that once cool helps a lot. But touch the roof, or just sit up and you can feel the HEAT on your head. I do love the colors, Granite Chrystal Metallic and black. Does anyone have any before and after results with the foam panels for sound deadening? Would they help repel heat? But my last truck was a white Colorado an a local Line-X guy sprayed the bed with a bright white coating that looked fantastic, repelled heat and it took was good care of wash and brush to wash, or alcohol on deep stains. Maybe a coating on the center flat spot at least 2” in all around.
SaiintNick
St George, Utah
2024 Mojave
Soccer Coach
I live in Southern Utah and have a black hardtop. Yes it's way hotter than my Sting Gray Wrangler was. Getting ceramic tint makes a huge difference and I believe Hot Heads help as well, but top still gets hot. Cools down quick once I roll windows down to let heat escape and then crank up the ac.
azmojave
Bobby
Phoenix, AZ
Mojave
Hothead Headliners do the trick. No more fried brain
@Hothead Headliners
LoneWolfUSMC
Southern Indiana
@Hothead Headliners
I installed the Quadratec headliners last month. I can tell a difference, even though it isn’t into the hot part of summer yet. I mainly installed them for some sound and echo reduction. The uncovered edges of the tops still radiate heat when they sit in the sun. I consider this kind of like the same reason that even a well insulated cooler works better with a white lid than a black lid.
Bandit’s Lair
Southern California
The headliners work the best for thermal protection. I went with CoverKing as I thought they looked the best out of all of them I have seen out there. There are a few threads here about it. Anything you can do to build a bit of mass between you and the roof will help. Roof rack with solar panels are something I’m looking into as well. An outer coating like on RVs could help too, but I’m not sure how they’d look. That rubber infused stuff you can get at big box stores is what I’ve seen used on the cheap.
Setec641A
Setec641A
Scooter
Maricopa, AZ
Earthling
Thank you for all the suggestions!
