Rear bumper LED lights
Tennessee Gladiator
Sevierville, Tn
2023 Overland
Added new rear bumper that has LED pod lights. Can I tap into my reverse LED light or will I have to run a wire to the aux switch? If I run it to the aux switch will I need an inline fuse and a relay?
D_JT
Travis
New Mexico
23 JT Rubi diesel, 19 JL Rubi, 00 TJ, 48 CJ2A
I would run it to a switch that way it doesn't turn on every time you back out of the Walmart parking lot. If you have factory aux switches, then no. You don't need a fuse or relay. I have a set of Baja Designs reverse lights wired to the #4 aux switch.
Brad.Clarkston
Brad
Kansas City
22 Gladiator Rubicon Sarge Green diesel
Sr. Network Eng.
That takes all the fun out of going to Walmart at night.
Tennessee Gladiator
Sevierville, Tn
2023 Overland
Thanks for the replies. I tapped into my trailer plug wire and works fine.
wasn't sure this would work because I had added a different grill with LED lights in a 2021 Ford Ranger with a LED light package and they wouldn't work.
Either or both.
My bumper-mounted backup lights come on in reverse, and I can turn them on with an aux switch. But to wire for both, you need diodes.......................
