Using selec-speed control as poor-man’s lockers.
93civej1
TN
Following this thread. I havent used this function yet, but may try it out sometime soon for fun.
bgott
Brad
LA.
2023 Willys, 2006 Dodge Ram diesel
retired
Be warned... It used the ABS system to regulate speed. It sounds like your gear train is coming apart when you activate it until the vehicle slows down to the speed it wants to see. I was playing in my yard in 4WD when I hit the button and thought I'd broken something. I had to do a search here to figure out what was going on, the manual doesn't mention the racket part.
Mojavie
South
2023 Jeep Gladiator Mojave
Hey Bgott,
I had the same experience the first time I used it, while testing the different settings. When I heard that grinding, I really thought something had screwed up, but like you said it was the ABS controlling the speed.
zxd9
Mark
Athens, GA
2021 Mojave Granite Crystal
Software Engineer
Be careful using it down steep grades for long periods. I lost my brakes on mountain switchbacks in CO at midnight. NOT fun! In my opinion I will now use 4LO first gear (and pump the brakes myself).
PW45
Phil
South Puget Sound
2021 Mojave
Dad, Veteran, Electrical Engineer
Be careful using it down steep grades for long periods. I lost my brakes on mountain switchbacks in CO at midnight. NOT fun! In my opinion I will now use 4LO first gear.
my selec speed only works in 4LO
Jefe1018
NV
Makes me realize how little capability the averag person will use - I’ve never used it either.
Kevin_D
Inland Northwest
@ShadowsPapa nicknamed it, "Duck Mode."
It only actuates in 4Lo.
I've used it with great results in snow.
A word of caution: if you're high-centered, or don't have some traction, DO NOT try it: it'll run the throttle up trying to increase speed, and the wheels will just spin!
LOL - good points!
zxd9
Mark
Athens, GA
Software Engineer
True. I should have added that I'll use 4Lo first gear and pump the brakes myself.
Zachanadandy
Zach
Patterson, ca
2023 gladiator Mojave
Electrical foreman
Left foot braking will outperform bld and select speed in my experience. Instead of the computer trying to modulate braking and throttle I prefer to do it myself. Traction and stability control off and drive using both feet in the sticky situations.
Kevin_D
Inland Northwest
I tried duck mode once. I absolutely hated it.
I'll do it myself instead.
You may hate it, or prefer to attempt modulating the brake and throttle yourself, but going uphill in a foot of heavy, wet snow, at ~3mph, with no slippage or loss of control, made me a believer!
cranbiz
Bob
Wentworth, NC
Been there, done that much younger and in MA. I have selectable lockers now if it ever gets that bad here in NC
Kevin_D
Inland Northwest
-You cannot react to slippage as fast as the traction control computer can.
-The traction control system/anti-lock brakes have control over individual wheel braking: you don't.
Just a couple of things to ponder...
cranbiz
Bob
Wentworth, NC
Man, I grew up in snow. I lived in MA for 47 years. I know how to drive in snow. No, I can't react as fast as a computer but then again, I don't have to.
I didn't say the duck mode was useless, I said I don't like the way it worked the couple of times I tried it. This fact, you cannot convince me otherwise.
