Wiring 3-position switch to separate switches?
MAG00
NE Texas
Jeep Gladiator '22 Willys; Jeep Wrangler '13 JKU
Const. Project Manager
My son has a light bar from rough country that has both white LED and amber DRL LED and it came with a pre-wired 3 position switch to operate it. He'd like to separate out the single 3 position switch into 2 separate switches on a control bank (spod, auxbeam, or other brand of switch controller). What is the best way to do that? Thanks.
ChrisNLA
Louisiana
2022 JT Sport Max Tow
Should be off in the center, and a light on top and bottom, right?
The center is typically power - bring that to each individual switch.
Take the top wire to one switch, the bottom wire to the other switch.
May not be exactly like that depending on how that product is wired, but you probably have one power in, and then a power out to each function.
ChrisNLA
Louisiana
https://s3.amazonaws.com/roughcountry/install/lights-drl.pdf
Yea the wiring diagram isn't detailed enough, but the switch probably has a power, a ground, a wire out to the amber DRL and a wire out to the white lights.
If you are using an SPOD or similar controller, you can throw away the Rough Country harness entirely (the switch and the relays) and connect the wires from the bar directly to the SPOD. The bar would have likely three wires coming from it. Amber DRL, white light, and ground. Amber to one switch output, white to one switch output, ground to ground.
MAG00
MAG00
NE Texas
Yes, that sounds correct. Switch off in the center, and main light bar led on one side and DRL led row on other side.
For the center wire ('common'), can I run it to one switch terminal and then take a wire and connect it over to the other switch terminal (like a jumper wire). This would be in lieu of splicing two wires onto the single "common" wire.
ChrisNLA
Louisiana
Yes, if you were simply adding an additional rocker switch, that would work since the switches are not carrying the load - the relays are. This is how we would do the 'old school' wiring on the trucks we build.
But again if you were going to any other controller with a switch pad, etc - you would be getting rid of nearly everything.
MAG00
MAG00
NE Texas
That sounds correct. I believe there are 3 wires coming from the light. Can I run the common ground to one switch terminal and then take a wire and connect it over to the other switch terminal (like a jumper wire)? This would be in lieu of splicing two wires onto the single "common" wire. OR would I even need to?
MAG00
MAG00
NE Texas
Yes, he would be getting rid of the factory supplied switch and replay and wiring into a switch pad like a spod or similar product. That being the case, I think I would be able to take the main light bar wire to one positive terminal for a switch, take the DRL row to a positive terminal for the other switch, and then run the common wire (ground) to both switches negative terminals. Does that sound correct?
ChrisNLA
Louisiana
Yep, that would be fine. Many of those pod systems have fuses rated for different loads - like two will be for 30A, two for 20A, and two for 10A (or some similar arrangement) so just make sure whatever ones are used meet the requirement for the light.
You can bring your ground to the ground terminal at each switch output, or to the main ground within the relay / control box. Each manufacturer and model is a little different. Higher amp draw items I like to go to the main ground in the box, lower draw I just use the ground provided with the switch output.
Alpine Warthog
Eric
Allegheny National Forest, PA
www.instagram.com
21 Gladiator, 98 XJ
Retired USAF Police Officer
I did the same thing with my KC Titans. ended up just going back to a 3 way switch since the whites overrode the amber.
test it out on the bench first, he may decide its not worth the hassle. You can also find controllers that have 3 way switches built in
ORACLElights
Peak Sponsor (Level 2)
Metairie, LA
www.oraclelights.com
Jeep Gladiator
Automotive LED Manufacturer
As Alpine said, some dual-color bars don’t love being split and will let white override amber no matter what. Easy to bench test before committing!
If you do want to simplify it, controllers like Trigger make this kind of setup pretty painless, but the concept stays the same either way.
ChrisNLA
Louisiana
Good point by those fellas as well. I've never owned such fancy lighting, so any overrides in the light are worth checking.
