2020 max tow/ should I swap for rubicon suspension?
Jeeperjamie
Jamie
Kannapolis nc
2020 jeep gladiator
Weyerhaeuser
@Gvsukids hey man, I looked at mine and they don't have the tags on them any more couldn't fine any numbers. When I have time to try, I'll look under there I will see if I can find a number stamped on them
Other two numbers? Meaning shocks?
No, you answered the question in the previous post. The 450 is a rear spring and the 339 is a front one.
Then I’m not sure what you’re asking when you ask what springs I was running.
There should be another 300 number for the other front spring.
Oh. The front springs a different because of weight distribution. Forgot that. I’ll check the other one.
Here we go again. Hope this helps. Rears appear to be 349 and 350. Fronts are 339 and 340. I didn’t pay attention to which side was which, but that should be easy to look up.
Jeep Gladiator 2020 max tow/ should I swap for rubicon suspension? 9578C741-A6E8-4127-8206-BE8DBDC4522C
Jeep Gladiator 2020 max tow/ should I swap for rubicon suspension? A8966966-8255-4635-B840-196213CA8711
Jeep Gladiator 2020 max tow/ should I swap for rubicon suspension? 9A4F3354-E575-428C-A15E-F64810916F0F
Jeep Gladiator 2020 max tow/ should I swap for rubicon suspension? BC8FA8D4-E9D0-409C-86EA-F1998BF013C4
jc10380
Ohio
Ford
FF
we’re you ever able to tell if they had a part number stamped on them? Looking at a set of take offs and only 1/4 has the tag.
