37s with 2 inch lift and tires hitting a plastic while fully stering
Xrubicon
San Diego
Jeep Gladiator Rubicon
hello everyone!
i have on my Rubicon Gladiator 37 tires with original rims and i have the full Falcon suspension as well as 2 inch spacers on all the rims and every time i have to park or make a tight turn the tires rub a plastic, the truth is i have not been able to find which plastic they rub since they do not have contact with any while I am parked turning the wheel (only in motion). I am thinking if it is the spacers i put or if i need to raise it one more step. What solution or alternative do you think I can do?
I have teraflex Suspension lift kit 3.5 and falcon shocks and 2 inch adapter/spacers
chsapeak
Dale
NorthEast
2022 Jeep Gladiator Diesel Rubicon Stingray
I'm running 37's on my Rubicon with a 2" lift and zero rub issues. My wheels are -12mm offset
Aberk
Atlanta
1997 Viper, 2020 Rubicon JT
You sure it is the plastic? My 37s rub the lower control a bit when at full lock and going forward. In reverse they don't do it.
bring44
Mars
2020 JT Rubicon
Professor
37" rims are huge! That's your problem right there!
mojocho
Ohio
I'd suggest finding a body and parking lot and try to see if you can find it.
I have a Rubi with 37"on stock rims AND stock lift. I don't have any rubbing on the street. Tires are General Grabbers x3
Renegade
Zac
Signal Mountain, TN
2020 JT
hello everyone!
i have on my Rubicon Gladiator 37 rims with original rims and i have the full Falcon suspension as well as 2 inch spacers on all the rims and every time i have to park or make a tight turn the tires rub a plastic, the truth is i have not been able to find which plastic they rub since they do not have contact with any while I am parked turning the wheel (only in motion). I am thinking if it is the spacers i put or if i need to raise it one more step. What solution or alternative do you think I can do?
Please clarify some, as your description seems a little off. When you say a "full Falcon suspension", are you referring to a Teraflex suspension system, with Falcon shocks? Those are currently available for the JT in 2.5" and 3.5". Or, maybe you have stock suspension with Falcon shocks added? When you say "2" spacers on all the rims", you are referring to wheel spacers/adapters, which move your stock wheels outward? I'm just trying to get an accurate picture of what you have going on.
Xrubicon
San Diego
Thanks for the observation ;)
