Do you need longer sway bar links with 1.5" front spacers? Shock extension?
Gladiatorx2
Knoxville Tn
Police Officer
I am putting on Terraflex 1.5 inch spacers on my Gladiator. Is there a need or advantage to adding longer sway bar links or shock extension? Thank you for your input.
ChrisNLA
Louisiana
2022 JT Sport Max Tow
I ran the stock links with no issues (same front lift). I do have Apex quick disconnect links now.
I still have the stock shocks in the front end. No issues there either - though they are probably limiting my front flex. I don't off road enough for it to be an issue.
Zachanadandy
Zach
Patterson, ca
2023 gladiator Mojave
Electrical foreman
The factory shocks will still work, but they definitely limit travel. Less than 8" of shock travel in the space you can now fit a set of rocksport shocks with 12"+. I wouldn't bother with extensions but I would replace the shocks personally.
BennieD
Bennie
Greenville
2024 Jeep Gladiator Rubicon X
Retired Law Enforcement
You don’t need anything
SamJ3
Sam
2022 Gladiator Sport
Technology Research and Advisory
I have a 2022 JT Sport running stock A/T tires. The only suspension modification is a 1.5" Teraflex leveler. That setup performs successfully across most trails I've run up to difficulty 6-7/10, though 7 is pushing it. (Need/want taller tires 🙂.)
kevman65
H
J
Don't need anything.
If you can find someone close that has a set of rear sway bar links available you could switch them out though.
Gladiatorx2
Gladiatorx2
Knoxville Tn
Police Officer
Thank you to all for your input/advice. They just looked so short to as my previous Rubicon had the AEV 2" and the links were much longer.
