Dead Aux Battery stops brake controller
LANGeek
MD
2020 Jeep Galdiator Rubicon
The aux battery was failing. The typical error light on the dash for the Start/Stop not functioning was lit. The interesting thing I found was tat the brake controller no longer worked either. The brake controller displayed an error indicating low voltage.
After swapping the Aux battery, an involved process, the brake controller is working fine again. Also the trouble light for the Start/Stop was extinguished and all is back to normal.
FYI: The brake controller is a RedArc wired into the Jeep's wiring harness
Labswine
Steven
West Chester, Pennsylvania
Retired Chemist
That could be bad if your start/stop battery sh*ts the bed while your on a trip and towing and suddenly your aux brake controller also commences to stop working...
Maybe this should be a safety issue brought up to those who build our Jeeps... @JeepCares
legacy_etu
New England, USA
Hmm, interesting. Where did you see the error specific to the brake controller not working?
RJinPV
Roger
Southern Cal
2023 JT Rubicon, 2017 Grand Cherokee Trailhawk
Thanks for sharing the experience. We'll all have a bit more knowledge to troubleshoot problems when we run across them.
LANGeek
LANGeek
MD
The brake controller itself blinks different patterns with colors.
legacy_etu
New England, USA
That’s what I was assuming but wanted to double check since I also have a Redarc waiting to install.
LANGeek
LANGeek
MD
The redarc works well and doesn't have the knee wrecking box as others do. It was fairly easy to install and setup. I like it.
legacy_etu
New England, USA
Yeah, it’s a nice unit. I love how compact it is. I’m planning on installing mine in the headlight housing switchplate on the left side. Now that Stellantis has eliminated one of the dimmer dials there’s lots of room on that plate.
Plumbob
Bob
White Oak. PA
2020 JT MaxTow, 2015 Harley Triglide, GMC Terrain
Plumber
Aux battery powers aux switches
