Dual-zone climate control issue
avere3
Dominick
Tennessee
2024 Gladiator Willys, 2001 Wrangler SE
I have a 2024 Gladiator Willys with the dual-zone climate control. As of tonight, I have 36,998 miles.
A couple days ago, I noticed that the passenger side vents were blowing air that was significantly warmer than what was coming out of the driver's side vents. Tonight, it was about 57 degrees on my drive home. Both sides were set to about 72 degrees, but the passenger's side was warm, and the driver's side was blowing cold air. I had to raise the temperature on the driver's side to 80 to feel heat that was anywhere close to the passenger's side vents. After a while, the driver's side still felt cool, and there wasn't a significant amount of heat unless I had it set to HI. I tried the Sync button, and it still felt much warmer on the passenger's side, no matter what the temperature was set to.
I thought I noticed this before, but then it seemed OK the next time I drove it. Is there a thermostat or something that has gone bad on the driver's side? Is there something that needs to be recalibrated? I hate that it happened less than 1000 miles out of warranty. I have an extended warranty, but it isn't the Mopar one.
GerryAZ
Gerry
Phoenix, AZ
2026 Willys '41 Edition
Electrical Engineer (semi-retired)
I might be confusing this with other vehicles. Some vehicles I have worked on recalibrate the dampers periodically and especially after battery disconnect. You might want to wait for other suggestions, but you could try disconnecting the batteries for a few minutes to clear system memory and initiate recalibration.
DylanM
Dylan
'21 JTRD
USAF Retired
The heater core is a singular unit, so if you're getting good heat on the passenger side then it's not a coolant flow or thermostat problem. On the dual zone climate system the driver and passenger side each have their own dedicated blend door to control the temp of the air coming out of the vents on each respective side, with the door positions being controlled by the HVAC module based on a number of inputs. The short of the matter is you'll need a scanner to look for any HVAC fault codes and to troubleshoot the system if it continues to act up.
SoK66
Jerry
Durango, CO
2021 Jeep Gladiator Sport (3)
Land Tours Manager, Jeep Tour Guide
Put the system on Sync and see if the temp stabilizes on both sides. Also check your coolant level. Top it up if necessary with the correct fluid.
avere3
avere3
Dominick
Tennessee
As stated above, even on Sync, it is much warmer on the passenger side.
If I put it on Auto this morning, the air was coming from the defrost vents, and possibly on the floor. It appeared to be blowing warm air, but not as hot as setting it manually to blow from the top vents. I need to see if the floor vents are blowing the correct temps.
The defroster is blowing hot air on the windshield.
SoK66
Jerry
Durango, CO
Ok, this sounds like what I experienced when I replaced both batteries a while ago. I had to let the system reset itself. Took a few hours. Have you had batteries replaced recently, or do you have any low voltage warnings? What is the voltage reading on the dash?
avere3
avere3
Dominick
Tennessee
Still on the original batteries. The dash display showed 14.8v while driving this morning. I'm going to disconnect the batteries tonight before I decide to make an appointment. I had wondered about this.
SoK66
Jerry
Durango, CO
Without starting it, press the start button to "ACC", let the screen scroll till it shows MPH, then use the toggle to get to voltage. If it's reading like 12v or lower your main battery is about to leave the chat, and the auxiliary is likely either the culprit or going out as well. The factory batteries are trash. If it's low replace boh at the same time.
Janster
Jandy
Lancaster, PA
2024 Gladiator Mojave X
Biller
I'm curious...... as I don't know. For dual zone climate control - wouldn't there be a 'thermometer' on each zone to read the temps? Where are they located?
avere3
avere3
Dominick
Tennessee
After sitting for over 8 hours, it showed 12.3v. It quickly went to 14.5v when I started it. The engine shut off when I stopped in traffic, and it dropped to 12.2v.
While driving home, I basically had to put it on HI on the driver's side to get any heat, which was actually too hot. If I put it on 84, it slowly dropped and then became cold.
Any recommendations for new batteries? I've seen a few people over the years say get an AGM battery from Walmart for half the cost of what the dealership wants.
Janster
Jandy
Lancaster, PA
Biller
I will say this… I had a recent visit to my dealership because my Auto Start Stop wasn’t working. Dealership charged my batteries and everything is fine now. Since this incident is on record with them - if the issue comes back, the dealership should replace my batteries under warranty (2024 with 20k miles). So, I’m hoping they die before March 2027 when my warranty runs out. 😉
A couple days prior to my visit to the dealership - the climate control was spitting out really hot air. I thought it was odd since my temp was set at 67. My husband thought it was the defrost on windowshield, like it sensed it was cold out side ( it was 45 degrees, hardly cold enough for defrosting). While driving, I adjusted the temp down to the lowest it would go and it did start pushing cold air out. I put it back up to 72 and it was fine. That happened 2 days in a row prior to my dealership visit.
The dealership did say…. When the batteries are getting low, the truck will automatically start ‘shutting off’ certain systems to conserve battery power.
SoK66
Jerry
Durango, CO
Intersting. That's a logical "feature" that's understandably not well explained by the manufacturer.
I'll just toss out here that when I replaced both batteries in my '23 Willys I got a couple of surprises. First, as part of the process I not only disconnected and insulated the main battery's terminals, before I dove into the auxiliary battery replacement I removed and insulated the primary ground to the body/chassis, located at the passenger side inner fender, so that there would be no chance an inadvertent cable short would damage the electronics. This removed all current to the system.
Reinstallation (positive first, ground second) went in sequence auxiliary battery, main battery, master ground. When the master ground was attached I got a small spark, which startled me. I hadn't taken into account there were a number of components and functions that would suddenly be energized. I had an "Uh oh!" moment when the climate control screen came back a different color, apps were missing, satellite radio was gone, and the temp controls only had max or minimums, nothing in between.
A Google revealed that when all power is removed from the Uconnect system it had to "re-learn" all of its settings. Within two hours everything was working normally and has stayed that way for the last month.
avere3
avere3
Dominick
Tennessee
I've heard about that before. Thanks for reminding me so I don't have a heart attack when I see it!
Just as an aside, my neighbors had a 2nd generation Compass with the 2.4L that had about 96,000 miles. They had the batteries replaced, then the ignition switch, and a few weeks later, the electronics went nuts. Lights flashing, gauges swinging wildly. The weirdest part is that it wouldn't shut off. We finally pulled the fuse to the fuel pump to shut it off. Then we had to disconnect the battery to get the headlights to turn off. This happened a couple times. The Jeep dealership couldn't fix it, and the place they bought it from wouldn't accept it as a trade until they had paid 6 more months on it. I'm hoping I never have a problem like this with the Gladiator.
DylanM
Dylan
'21 JTRD
USAF Retired
The dual zone HVAC system uses four duct temperature sensors to determine air temps on each side. Two are located in the HVAC housing and the other two in the left and right lower outlet ducts. There's also a cabin sensor located in the dash just forward of the driver's knee (that's what the little vent is for below the ignition switch), and a sun sensor located on top of the dash near the defroster vent.
avere3
avere3
Dominick
Tennessee
Alright, I disconnected the batteries around 11am today. I ordered a main battery from Walmart and picked it up. I asked O'Reilly if they had an Aux battery (because Walmart would have taken 3 days to arrive), and they said they could order one and have it by 4pm today. I took the main battery home and set it in place. At 4:30, my wife got home and we went to get the Aux battery.
When I went in the store, the kid said he wanted to compare my old battery to the new one. He said he thought it should have been one of the small batteries on the shelf, but the system led him to order a different one. When he compared them, he said the one they ordered was huge, and the one on the shelf matched mine. Keep in mind I had the old battery with me when I went in to ask if they had one... So, if they had looked at the one on the shelf, I could have had my batteries by noon and reassembled the truck before my wife got home from work.
That would have come in handy because it was dark by the time I got home with the Aux battery. I got everything installed and started the truck. Everything seemed OK other than the clock. I MIGHT have had one of the fuel economy screens missing for a few minutes. So I installed the front tire and took it for a drive.
The HVAC is still FUBARed. If I set them both on 72 degrees, the driver's side is still COLD and the passenger's side is warm. I kept the passenger's side at 72 and slowly bumped up the driver's side til they felt the same on my hand. The driver's side stayed cold the entire time until I hit HI, which felt like sitting on the face of the sun. I slowly backed down the temp, and it gradually went down. When the driver's side was on 80, it was close to the other side on 72. This is what I have noticed the last few days, also. The interior was warmer with the HVAC set to OFF than it was with the driver's side set to anything other than HI.
I drove around for a bit, and it still feels the same as it had been. When I check the voltage on the screen, it appears to be 0.5V higher both with and without the engine running. Readings are 12.8 and 14.9 vs 12.3 and 14.4. Auto Stop/Start works as it had been.
I need to see what the air feels like from the lower vents, because I can't feel much of anything on the driver's side while wearing jeans. I guess I'll do that now.
So, unless it's going to reset something overnight or as I drive it, I feel like I wasted my money here. I guess I need to find out if my third-party warranty will cover anything if I take it in this week.
