Front/Rear Diff | Transfer Case Maintenance
SCLaunch
2020 Jeep Gladiator
Every time I go into stealership, they recommend the 30k Front/Rear Diff and Transfer Case Maintenance. Is that just fluid changes? Is it critical?
jwilson2899
Front Royal, VA
System Engineer
It's just a fluid change on all 3. Technically though they're recommending it at the wrong mileage. Per the owners manual it should be 40k for the diffs and 60k for the transfer case. It is something you should do for longevity.
Gatorac
Jim
Bradenton FL
20 Sport S Max Tow, Audi Sq5, 2000 TJ, MX5 Track Car.
General Manager Chin Track Days
I just completed this service. It's super easy to do. I spent less than $70 on the fluids.
kevman65
H
J
If you drive off road a LOT, then your intervals are shorter.
If you tow a LOT, then your intervals are shorter.
It is something important to do to keep all your 4x4 parts happy.
bd100
USA Midwest
JT, WK2, ole' Ram
If you tow then the back diff works much harder than the front diff, so the front diff can be done less often than the others. I did all at 20K miles or so and the front was still like new. But if you tow change at least the back more often. And the transmission too.
If you offroad a lot then the transfer case works harder and so you should change it more often. Otherwise the factory intervals are probably fine. It looks fine on mine at 20K miles.
SoK66
Jerry
Durango, CO
2021 Jeep Gladiator Sport (3)
Land Tours Manager, Jeep Tour Guide
30 k is a good interval for all 3. Relatively easy to do yourself.
You got a 2020, so that means drain plugs on everything. Very easy to do yourself in a driveway and some basic tools. Plenty of videos on the tubes showing how to do it. Easily be done for 1/3-1/4 the cost that any dealer will charge you.
