How to drain DEF tank?
HereWeGo
Kenny
Fort Walton Beach FL
2021 Jeep Gladiator Rubicon
Got the EOC Stage 1 tune installed. Need to drain the DEF, but no idea how. A siphon tube down the filler hole does not work. Anyone know the best way to drain the DEF?.
Is the DEF tank behind the gas tank? Everything is covered in skid plates, so I can't see it.
Any advice appreciated.
thanks
biodiesel
New Mexico
2015 Ram 1500 Ecodiesel
If you follow the DEF filler hose down to the DEF tank, then you should be able to disconnect the hose where it connects to the tank. From there, it's easy to siphon the DEF out.
Koolcarguy
Shane
2021 Hydro blue Jt 2012 Gecko green Jk 2021 Gecko
Car dealer
thanks
Keep us posted on how you like the tune Those guy's do a great job haven't had a Jt tuned yet....
MikeD93
Michael
Drayton ON Canada
2022 Jeep Gladiator Rubicon
310T Mechanic
If you find a drain plug let me know. Waiting on my down pipe from them and then I’m going stage 2
HereWeGo
HereWeGo
Kenny
Have you done this? I can't follow it down with the skids on. Is the DEF tank behind the fuel tank?
biodiesel
New Mexico
I removed the fill hose on my 2015 EcoDiesel and siphoned the DEF out. You will need to remove the skid plate to gain access. I have not done it on the Gladiator, though.
HereWeGo
HereWeGo
Kenny
HereWeGo
HereWeGo
Kenny
Remove skid plate from def tank. Then remove the 3 screws holding the pump in. Remove pump and let drain. will take about an hour to drain completely. Easy peasy.
AWESOME! That's what I was looking for. Thank you for the reply!! :clap:
Kansass
Bicycle
Are you going to do the pipe that goes from the down pipe then reconnects to the existing exhaust flange just in front of the rear axle? Does the one you ordered have a resonator? I want to get a new exhaust that sounds good but I don’t want it to be so loud I get unwanted attention. Its tough to choose without ever hearing one.
MikeD93
Michael
Drayton ON Canada
310T Mechanic
Yeah I won’t have a resonator but I’m still using the stock exhaust. Once it’s all done I can make a video, I agree I wouldn’t want to do a straight pipe but I want a bit of noise
Kansass
Bicycle
Nice! Are you gonna do the multi map or the one tune. I can’t decide on that either
MikeD93
Michael
Drayton ON Canada
310T Mechanic
I have adaptive cruise so I can only do the single tune. I think I’m going to go with the street tune. The race tune just seems like it’s going to burn up the transmission
