LED bulb replacement advise
Rrcar
RC
CA
2024 Jeep Gladiator Nighthawk
I have a 2024 Gladiator Sport with Nighthawk package. I ordered some DRL (daytime running lights)LED’s which said they were for Sahara and Rubicon I think it was. And also compatible with a Sport model with some kind of tow package, which I do have the tow package but not sure if it’s the same one required. Long story short, they don’t work. One worked but when u put 2nd in, that one wouldn’t work. Put the factory halogens back in and both halogens worked again (thankfully). Can anyone recommend a vendor or direct me specifically to LED’s that are just plug-in play with no special wiring or is there such a thing? Thanks
What Y-Guy said. Going to need a scan tool like a Tazer or JScan to edit the DRL settings in the BCM to set the DRL's as LED's now instead of Halogens.
Another way is to put resistor inline and make the BCM think the LED's are halogens.
Rrcar
RC
CA
Update…thx to the advise here, did the J SCAN thing, changed 1 little setting to DRL LED and they work perfect. Hardest part was unplugging BCM/ ECM??? From under steering wheel….thx for the help
