Led best bulb replacement
NightHawk2025
2025 gladiator nighthawk
Have a 2025 jeep gladiator nighthawk what's the best bulbs to use ? Any suggestions out there 🤔
ORACLElights
Peak Sponsor (Level 2)
Metairie, LA
www.oraclelights.com
Jeep Gladiator
Automotive LED Manufacturer
A full LED headlight unit is where you’re going to see the biggest difference — cleaner beam pattern, way better distance, and no weird scatter if you end up going with the wrong brand.
The Oculus LEDs are a solid pick for the Gladiator, and they’re usually priced really well around Black Friday. Just throwing that out there if you’re already planning to upgrade for winter driving!
harryator
Harry
East Coast
Jeep Gladiator
A few years back, I got a variation of this model replacing Halogens on my gladiator.
https://a.co/d/hL3zxzO
I had to slightly re-aim/lower the headlights since the LEDs throw much more light than the OE Halogens.
The LED diode orientation within the headlight housing is an important thing to note. There are a few posts about the right orientation so that the high-beam diode and the low-beam diode are pointing in the right direction.
Been a few years and its been running well. Hasn't bothered other drivers on the road.
ChrisNLA
Louisiana
2022 JT Sport Max Tow
I ran a set just like this and had no problems for three years, then one of them started to fail.
I went back to Sylvania Xtra Vision's (regular bulbs), and funny enough I get flashed often with these, but rarely did with my LED's, and my headlights are pointed down some from when I did the LED swap 😄
D_JT
Travis
New Mexico
23 JT Rubi diesel, 19 JL Rubi, 00 TJ, 48 CJ2A
Don't use LED replacement bulbs. They look tacky and they blind everyone. Go with a full headlight replacment.
