Mopar 2 inch Leveling Kit?
vh5150
Marc
Chicgo
Gladiator Willys 2021
Hi all - I can't seem to find much info on a mopar leveling kit (not the lift kit). My dealer has offered this as an option and I am trying to find out more info as I dont know if it is a straight front and back 2 inches or just the front. Or if there are other options with this like with the teraflex one. Any information you all might have would be appreciated.
CerOf
Dallas
‘21 JTRD
To my knowledge there isn’t a 2” leveling kit offered by mopar. Most likely your dealer uses some lift companies spacers.
Why do you want spacers and not the actual springs to get you 2”?
vh5150
Marc
Chicgo
I am just trying to understand the offering from the dealership. The also offer the Mopar 2 inch lift kit, which I understand is more like 3.5 inches of lift. Because I dont want a full 3.5 inches of lift wanted to better understand their "Mopar Leveling Kit" which I am coming up short on. I am waiting on more details from the dealership.
CerOf
Dallas
‘21 JTRD
The mopar lift will net you 2” if a Rubicon.
Almost 3” if a non-rubicon.
If you just want looks and larger tires, spacers are the way.
If you want increased off-road performance, springs are way to go.
vh5150
Marc
Chicgo
Thank you that helps!
Ar4130
Alaska
JK, JT
If they are saying its a leveling kit, it is only the front. It's used to "level" the truck out and remove the factory rake (lower front end)
Wheelin98TJ
Devils Lake, MI
2021 Jeep Gladiator
Bean Counter
Ask the dealer.
Maybe it’s just the Mopar front springs plus whatever else they decided to include.
Aonarch
Alec
GA/ MT
Mopar does not make a leveling kit.
A leveling kit, generally speaking, means coilovers/ coil spring spacers. Made of plastic, rubber, polyurethane, or metal.
They probably just slap a $75 spacer on the front and charge you $500 for it. Nice little profit. A tech can knock it out in half an hour or less.
With lift kits, do it right the first time. Buy once, cry once. Etc.
