Sector shaft brace
BigRed97
Boston, MA
Gladiator Sport S
Couple tips if you don’t mind, it’s suggested to remove the tire and of course I’m smarter than anyone, if you don’t believe me just ask me. I didn’t do that but wish I would have as I do believe it would have been easier. Also it takes a lot of finagling, tightening and loosening to get all the bolts started/lined up which is why I think removing the tire (like they suggest) makes it easier. Good luck and please reply back on how it drives
Definitely take the tire off, but no need to take the sway bar down like the instructions say... Plenty of space.
For me a the holes lined up perfectly
Honestly the install was about 15-20 minutes. Super easy
Lynn_F
Lynn
Fannett, Tx
2020 Gladiator Sport S
I installed the brace and it eliminated the wobble that was periodically occurring. It was a fairly easy install and I agree that the sway bar links dont need to be disconnected but the tire does need to be removed. I am pleased overall with the steering after replacing the stabilizer and adding this brace but am pretty disappointed that it took $400 of my dollars to get it to drive normally...this should be addressed by the factory but I am not certain it ever will. I had to deal with the lifter/head issue on my 2014 JKU and they eventually repaired it but not without a huge fight.
BigRed97
Boston, MA
Gladiator Sport S
I was going to get the teraflex adjustable stabilizer too but decided to wait and see what the brace did alone. I'm satisfied and don't feel that I need the stabilizer now.
Lynn_F
Lynn
Fannett, Tx
For me, the stabilizer helped reduce the wander and the brace helped with the wobble that I would get when I hit certain spots on the road.
TJ Mitchell Films
TJ
CA
www.YouTube.com
Red Rubicon JT
Welder
How many of you have this installed and has it made a difference? I don't have a problem with my steering being loose but there is a lot of wandering especially with gusts of wind. The wandering doesn't seem normal to me as I have owned plenty of Jeep Wranglers and CJs in the past and haven't experienced this. I just want to know if this brace helps with this or just the loose steering. Thank you in advance for any information.
Murray in this video you can see the steering box moving off the frame and how after the brace is installed it doesn’t move. Night and day difference.
Renegade
Zac
Signal Mountain, TN
2020 JT
Hey, I had seen that when you originally posted it, but am curious- Did you check that bolt to see if it was tight? Mine steers well, but I am always aware of this issue and want to be able to solve it if it happens. Thanks.
TJ Mitchell Films
TJ
CA
www.YouTube.com
Red Rubicon JT
Welder
Which bolt are you referring to? All of the bolts were tight on the original steering set up.
BigRed97
Boston, MA
Gladiator Sport S
Mine steered "well" too, I didn't have the slop that many do. However I didnt realize just how badly affected it was by bumps and what not until after i installed the brace.
And after seeing these videos this is something I would put in preemptively, out of concern of metal fatigue around the box. May be over thinking but peace of mind...
furrymurray
furrymurray
Michael
Saint Amant Louisiana
2020 Jeep Gladiator SG Rubicon
Great video! just like you, my steering is not bad. When I give the steering wheel input there is no lag or dead spots, the wheels are turning immediately. My issue is with the wandering and not being able to hold a straight line while driving. I have heard that this sector shaft brace will fix that and that is what I am hoping because I ordered one. Thank you for the videos and keep up the good work.
BigRed97
Boston, MA
Gladiator Sport S
If there was play between the steering box and the frame, were the bolts loose?
It's not play BETWEEN them, the frame flexes from the force of the steering acting thru the box and bolts. The brace stiffens up the area and distributes the load better
Blade1668
Darrell
N. AL.
Seeing that video makes me wonder if the frame is not sleeved where the steering gearbox bolts on. This has been a problem in the past on many other vehicle's
BigRed97
Boston, MA
Gladiator Sport S
Very possible. I didn't even think to check when i installed the brace
Blade1668
Darrell
N. AL.
BigRed97
Hopefully someone will check it out when they install the bracket and post it on here.
