Will RSI SmartCap fit with AEV Vertical Tire Carrier & 37" Tire
JasonFriday
Denver, Colorado
2025 AEV Gladiator
I have a 2025 Gladiator Rubicon X with the American Expedition Vehicles vertical tire carrier and a 37" BFG MT. Has anyone installed the RSI SmartCap with this setup and were there any clearance issues / modifications required?
Jeep Gladiator Will RSI SmartCap fit with AEV Vertical Tire Carrier & 37" Tire IMG_5477
Jeep Gladiator Will RSI SmartCap fit with AEV Vertical Tire Carrier & 37" Tire IMG_5478
Thunderspud
Angus
Can't speak to your specific scenario... but in the event no one responds I am happy to take whatever measurements you need when I am near the truck again. I have the Defender on the truck in the profile pic. Might be later tonight, or (more likely) on the morrow.
Bandit’s Lair
Southern California
2021 Gladiator Sport S
Not sure on the RSI but the OVS sit just slightly taller than the cab of the Gladiator so should have no problem fitting. If I remember right the RSI is even with the cab.
azmojave
Bobby
Phoenix, AZ
Mojave
IDK why AEV does that when a 37 will fit under the bed. It looks cool, but I’d rather have the tire out of the way.
Amazing truck BTW. I’m definitely jealous :)
Jaxmax
Jack
Bally, Pa.
Electrical Manager
Well without checking the measurement inside for the height it looked like yours was low enough but perhaps if 38s are in the future you might have a problem, get a measurement from high rib on floor top of tire.
I took a photo in the dark ,the RSI cap hangs over the inside of the bed about 1/2”, hard to tell from your picture but looks like a pipe frame or something is there, guess spacers under the bolts could solve that. Anyway it’s what I got in the dark tonight!….Jack
Jeep Gladiator Will RSI SmartCap fit with AEV Vertical Tire Carrier & 37" Tire IMG_6181
Jeep Gladiator Will RSI SmartCap fit with AEV Vertical Tire Carrier & 37" Tire IMG_6182
Vtur
Le
Norcal
JTOD
Electrical Foreman
Agree. I can’t imaging pulling that tire out on a trail when need it, with likely bunch of craps in front of it to removes too.
JasonFriday
Denver, Colorado
2025 AEV Gladiator
Thanks all. I will pull it outside and take some measurements and better pictures today.
JasonFriday
Denver, Colorado
2025 AEV Gladiator
Hi all. I finally had time to take some measurements and better pictures. The tire mount is attached to the Mopar Trail Rail system so it sits ~1.5" out from the front edge of the bed. It extends ~20.5" vertically above the edge of the bed which is below cab height by ~1.5" or so.
Jeep Gladiator Will RSI SmartCap fit with AEV Vertical Tire Carrier & 37" Tire IMG_5847
Jeep Gladiator Will RSI SmartCap fit with AEV Vertical Tire Carrier & 37" Tire IMG_5848
Jeep Gladiator Will RSI SmartCap fit with AEV Vertical Tire Carrier & 37" Tire IMG_5849
SmartCap
Peak Sponsor (Level 2)
Nevada
www.smartcap.com
Gladiator, Tacoma, Tundra, F Series, Silverado...
Hi Jason–
Here is a diagram showing the dimensions of our EVO series SmartCap. The height of the cap from the bedrail to the top of the cap is 550mm (appx. 21.6").
