JTGuy
Pascual
San Dimas CA
20022 Jeep Gladiator
Manager
I don't have a hi lift jack but if I did, I would keep it handy mounted to the wall of my garage. I keep my trail tools in a heavy canvas zippered tool bag. Easy to pack.
PuddleJumper
Cortlund
Alexandria, Virginia
23' JTM, 22' JTR, 22' F56S,
just out of curiosity what have you used that farm jack for?
ive only seen one used 1 time in person in 20 years of wheeling and it was a failed attempt as a come along substitute
I use mine as more of a farm tool than offroad recovery device. Its great for pulling fence post, jacking up fallen trailer hitches, come along (if done right), and taking up garage space. TBH i would only take this on a recovery, If I knew a 1/2 ton pickup or larger was really stuck. But in use on a personal vehicle, you need frame mounted HD sliders and a d ring on every corner, and even then its not your first choice. On IFS vehicles Its almost useless.
PuddleJumper
Cortlund
I carry 2 bottle jacks 24/7 and a pro eagle anytime I intentionally go off road
That sounds a lot heavier and a triple threat if that shit ever goes flying. But definitely far more useful in a lot cases as well.
stingrey
Paul
Ontario, Canada
2020 Rubicon
Civil Eng.
..another derailed thread. :LOL:
I like your ammo can solution. Cost effective and practical.
Hard to read on my phone - Is it a .50 cal can?
I have been planning to attach a couple on the unistrut rails, under my Diamondback Cover. It's been over a year and I never got around to it. Hope this motivates me to get it done.
Dickster
Hillsboro, OR
2021 gladiator rubicon, 2022 Ram 3500 6.7L
Sheet metal
Bottle jacks and bottles of Jack... both handy in a pinch.
bottle jack fails just toss the cap away on the jack and a jacked up situation is all better.
Dickster
Hillsboro, OR
Sheet metal
not fully derailed but a jack could get it back up right:CWL:
TheSolarWizard
Memphis
sun belt
3.0 JT
Solar & EV infrastructure
Oh absolutely.
in the new setup the jacks will be strapped inside a toolbox and the roller pinned into my gear plate in the bed
Dickster
Hillsboro, OR
Sheet metal
These are great options but they certainly cost a lot more than my method. My method cost almost nothing as I already had the unistrut rails mounted, add a few nuts and 8 inches of unistrut and Bobs your uncle.
I get it, my method is not as clean as having a molle system, but I like homemade stuff.
Not dogging your idea I like it. I was adding to your idea if that is ok? Molle panel would let you move it around very easy. Cost is always a concern and your way works and its simple.
BourbonRunner
Baltimore
Foole
Blade1668
Darrell
N. AL.
I do have a short length of cable locking it to the cargo tie-down. its on the end you can't see in the pick.
For a lock on ammo can here's a easy way.
Jeep Gladiator Ammo box bed toolbox project 20240803_011657
On High-Lift jacks, I have 2 functional ones. 1 stays in my LJ mounted between roll bars in back. The other is the the 60in one in a jack box that was always on my XJ. Heavy S.O.B. but I've used both for so many different jobs besides jacking up a vehicle. The handle has been used to sleeve steering linkage to get me home even. As a hand winch to recover a stuck 4wheeler in a swamp "then broken" the OEM Warn winch failed. Operator ignorance in winch use. "Mostly"
My first High-Lift failed when new as I tested it out, the climbing leg was bad casting. Do I recommend a High-Lift jack? Not to anyone who doesn't spend the time to know how to use them and take care of it.
Another ammo can in bed mounted on strut to help motivate.
Blade1668
Darrell
N. AL.
CelticKnot
Kyle
Austin, TX
IT
That's a nice mod. I have a low-profile Milwaukee storage bin that I bought from Home Depot for storing jumper cables, tools, a small air compressor, first aid kit, sun screen, bug spray, you know. The essentials. It has a thick gasket so is waterproof.
I like that yours is fixed to the body; mine is loose but I do have a tonneau cover.
