- First Name
- Bill
- Jul 22, 2019
- 38
- 6,663
- 7,788
- North Las Vegas, NV
- 2023 Gladiator High Altitude - 2013 Nissan Leaf SV
- Vehicle Showcase
- 1
Just pulling the IBS from the negative post during the swap usually resets it. It has been recommended to fully disconnect it for at least 10 minutes to ensure a reset.Removing the fuse box doesn't look like that big of a deal. More of an annoyance than anything else. I already watched a video of [Banned Site] do it on his JL Wrangler and took notes on it w/pictures.
BTW He didn't remove the IBS or anything.. all he did was disconnect the negative and positive leads from the main battery, then remove the aux battery and do the same.. put in the new aux, connect it, put in the new main, and connect it.
He didn't even disconnect either wire from the ground he just disconnected the entire - and + cables from the terminals leaving all other cables attached to them. Didn't seem to have a problem.
Is it really necessary to reconnect the IBS or reset it? or even fully charge them?
The IBS relearn process works better if both batteries are fully charged before installation. The 'smart' charging system uses the data from the IBS to make decisions on adjusting the alternator output.
