Coolant Expansion Tank: Leaking
Orange01z28
Andrew
Queen Creek Arizona
2020 JTR
My coolant expansion reservoir was pissing when it got hot, like on a long day of wheeling. I reseated the hose, and it got a little better but there's still witness marks of small seeping and I can smell coolant. The dealer checked it out today, and it's not covered under my extended warranty, nor could they get the part today so I ended up declining the work
It seems dead simple to do myself, my only question is do I just get the stock, plastic replacement or is it worth spending more on one of the aluminum ones?
DylanM
Dylan
'21 JTRD
USAF Retired
I would stick with the stock plastic replacement myself as it's much easier to check the fluid level.
Are you sure it's the tank that's seeping and not the o-ring seal in the hose connection?
Orange01z28
Orange01z28
Andrew
Queen Creek Arizona
2020 JTR
That’s a good point. It seems to be leaking from the connection
I’ll check that
DylanM
Dylan
'21 JTRD
USAF Retired
Bandit’s Lair
Southern California
2021 Gladiator Sport S
Only one I've heard of the reservoir being a common problem is with the 2.0 engine in the JL.
To my recollection, the seams have been found to be weak and fail on some of them. Don’t hold me to that, and I haven’t really researched it in depth. I just look into things that could potentially fail when I don’t want them to and seek solutions. My goal is a vehicle I have no reservations taking 75-100 miles out into the desert, beat on it to a reasonable level, and make it home. Stronger than plastic components give me that peace of mind.
tysongladiator
Tyson
Jeep Gladiator, Jeep Wrangler
Learner
If it leaks from the bottom, it's possible that the connector is broken and an aluminum reservoir won't fix that. It's the hose connection itself. If it leaks from the top, it's most likely the inlet where the hose connects to. An aluminum reservoir would fix that. Determine where the leak is coming from first.
I've replaced mine twice with a factory tank. It's simple and quick. The first time it was the connector. I thought it was the tank, but it wasn't But since I had already bought it, I replace it anyway. The second time, it was the inlet on top. I may change to the aluminum if I have another reservoir issue. I just like being able to see where the coolant level is at all times.
Orange01z28
Orange01z28
Andrew
Queen Creek Arizona
2020 JTR
Mine's leaking exactly where yours is. I figure I'll just go aluminium since I live in the desert and plastic just doesn't last here
tysongladiator
Tyson
Learner
Oh yea. In that type of climate, I would definitely go aluminum. I didn't go aluminum because I was out of town and I had to get what I can. I had to find the closest dealership where I can get one that day. Otherwise, I would have went aluminum. Had one sitting in the cart. Lol
My first one leaked from the bottom. Crazy thing though. The tank on the JT/JL come with a tiny metal sleeve inside the nozzle that is supposed to help with unintentional brakeage. Well... the dealership told me that the ones on the Chargers and Challengers don't even have that metal sleeve and they have issues all the time. I guess that would be my first purchase if I had a new Dodge car.
But yea... go with the aluminum. Make sure it has a sight glass. Lol. I've seen some that doesn't have one.
