eco diesel low oil pressure light
salmon scott
scott
corona
2023 jeep rubicon gladiator
electrician
have 15,550 miles two weeks into my third oil change the light comes on for low oil pressure i imedietlyput oil pressure on dash it goes down to 12 psi as im pulling into a parking lot drops to 6 psi i shut it off check oil oil level is fine after half hour i start and everything is fine oil pressure back up to 35 wtf
nanook12
Alaska
2023 Jeep Gladiator Rubicon
Mine will drop to 20psi at idle (hot). Check your o rings on the filter? Or just change the filter
salmon scott
scott
corona
electrician
this went down to 6 psi before i shut it off / new docs filter with 200 miles on oil change after i let it sit and checked fluids i started it up and oil pressure was 60 psi at first then went down to 35
Thunderspud
Angus
No idea what's wrong with your truck. However, if I may, a related suggestion: try typing your actual question/concern instead of relying on (what I assume is) text-to-speech. You may end up with something a bit more coherent. More people may then be willing to chime in.
Good luck.
Vtur
Le
Norcal
JTOD
Electrical Foreman
Try reinstall the filter or replaced with another one. You will get low pressure if the output port oring or the bypass valve oring isn't sealling. Fully warmed up should be around 18-19 psi at idle. Aftermarket filter plastic cartridge material may be different than oem and could deformed under hot oil.
SKJeep
SKennedy
Kansas
2021 JTRD, 2022 JLUD, 2014 JK
Simple things first. Double check the tightness of the oil filter to make sure it fully seated and tightened. Then what @Vtur said, replace the filter.
69charged
Manitoba
23 JTRD
Mopar only sells the filter with a new cap for this reason. People were not installing the filter correctly in the cap. Is it possible that happened? Although it should have happened right away I guess.
Just a thought.
Vtur
Le
Norcal
JTOD
Electrical Foreman
That's your problem. Doc's filters are garbage. Go back to Mopar or a different aftermarket brand.
It's a red flag when a company advertised a filter as high flow but the media cartridge shape and micron rating are the same as factory. Where's the additional flow comes from? Cellulose or synthetic media materials?
Most of them can advertises whatever they wanted knowing majority of the consumers has no ways of verifying and or testing their products.
biodiesel
New Mexico
2015 Ram 1500 Ecodiesel
Doc's doesn't even design or manufacture their filters. Their filters are sourced in different locations. I can't tell you how many times people have had oil leaks, fitment issues, and low-pressure codes when using Doc's.
Doc's is notorious for putting money into advertisements, commercials, and other clever social media pandering. They are just a reseller, not a true filter or oil brand.
alpineovernappa
Mid-Atlantic
2021 JTSS 3.0 & 2006 LJ 6mt
I started having this issue intermittently after I had the HPFP replaced under recall (no failure, 62k miles). My gut feeling was that it had something to do with the software update they did at the time, as oil pressure in these vehicles is a triangulation of sensor data, not reliant on an actual oil pressure sending unit. If you were still under warranty, I would take it in and have it documented just in case you do have a mechanical issue. If you are outside of warranty I would suggest doing a full oil change with Mopar filter and sending an oil sample in for testing (blackstone or similar). If the jeep is running fine and temperatures look good and the pressure shoots up to a normal range a few seconds after the error, this is likely just a software glitch. When the error pops up, I would turn the vehicle off and then immediately turn it back on and see if it re-presents.
Obviously, if the jeep is acting strange in any way or running hot, you should not drive it or turn it on in any capacity. I would strongly suggest sticking with OEM filters sourced from a reputable place (not Amazon or eBay).
