Surffisher2a
- Oct 4, 2020
- 3
- 48
- 40
- Coastal North Carolina
- 2021 Gladiator Mojave and 2021 Wrangler Unlimited Sahara
- Occupation
- IT Manager
I recently got a 2021 Mojave Gladiator and took it out on the beach driving. I had it in 4 high and turned the ESC (Electronic stability / Traction control) off. When I was driving i noticed a metal on metal grinding noise and felt vibration in the steering wheel when going over some bumps / ruts in the beach. Everytime this happened the ESC light flashed (The light under the ESC OFF indicator light). I was not using the off road +. mode.
I did some searching around and found multiple threads where people said noise was normal, and the owners manual said there might be clicking or buzzing sounds. However this sound was metal on metal grinding sound and nothing like you hear when the ABS braking kicks in.
So I guess I have two questions:
#1 is the metal on metal grinding sound normal when the ESC kicks in ?
#2 why would the ESC be kicking in at all if it was turned off (The ESC off indicator was lit on the dash) ?
Once i started hearing the noise I turned around and slowly got off the beach because I didn't want to make anything worse or get stranded. I did try to turn the ESC back on and still had the exact same issue. Next time I go on the beach I am going to try Off road+ or/and 4-lo to see if I have the same issue. I do have a scheduled service apt. with my dealer for another minor issue (Handle on transfercase selector slides right off in my hand). I am going to bring up the traction control issue with them to check. I just want some other opinions on the issue before they blow me off and tell me noise is normal and not even look at anything.
