- First Name
- Bill
- Oct 12, 2019
- 250
- 40,624
- 54,314
- Runnells, Iowa
- Occupation
- Vehicle Showcase
- 3
Here is the tech behind the warnings -Yeah, it was the negative that sparked. Positive just kinda stayed in the red rubbery protector.
When you remove the cable assembly from the main battery, the small aux battery is still connected down below. The positive of it can feed back through the fuses to the positive cable you removed from the main battery. And since the aux battery grounds to the cable you removed,. the other end of which is still connected to the chassis and block, letting that red cable end touch ground can blow that fuse. That fuse is part of a long array of fuses and it's somewhere just south of $200 as I recall.
I usually wrap a rag about the positive if I remove it - even tape the rag onto it. Call me paranoid, or just assume I hate it when I break something that wasn't broken before I started fixing the other thing!
Again, I think you are fine since it was the negative that sparked and that's normal.
I had the negative off mine today to test a theory and it sparked when it touched the terminal again to reconnect it. Normal.
