Cburd61
- Jun 28, 2020
- 15
- 571
- 1,590
- South carolina
- 2020 Gladiator Overland
By the way, if you weren’t 2800 miles away, I would help try to get it out.
Ha! It’s the thought that counts!!By the way, if you weren’t 2800 miles away, I would help try to get it out.
Correct and that is pretty much with any modern medical electronic implant device. They are shielded pretty well but there is still a emitter and receiver function of the devices that are susceptible to EMI interference in the right conditions.
When I got my device some years ago, I had to go through a audit questionnaire of my working history and daily access to RF type energy. Working in Avionics Engineering design and manufacturing, I have to watch what environments I am in. People in trades that use either direct energy devices and unshielded EMI environments like plasma cutting, arc welding and use of tools like the already mentioned induction coil heaters have to take even more precautions or in some cases, find another trade.
Oh man, that sounds fun. How did your wife do through that? Docs want to do a full brain map for me as well. But were surprised to find out the x-ray showed 9 screws and some titanium threads flapping in the wind when the last surgery was supposed to remove ALL the hardware and metal. :-/ Hopefully her surgeries were without complications!!To have the probes implanted. It's a 5 step process.
1st step to have 4 tiny screws put into your skull. One at each corner. This is like surveyor's markers for the next step.
2nd step a week later. Complete brain scan. They are mapping your brain. Using this mapping. They will make a skull cap to fit your head. This is the drill jig to accurately drill into your skull.
3rd step is about 2 week from the 2nd step. Need time to make the skull cap. They will put you asleep. place the cap on your head. Drill the holes in your skull. Place the probes into your brain. Then they wake you up. Test the probes and make adjust on the depth of the probes. Put you back asleep. The wires for the probes are not hooked up at this time. They are bunched up under your skin.
4th step is a week later were they connect the wires to the control devise. They run the wires under the skin. Behind your ear, down to your chest, where they have implanted the control devise. They will make some small adjustments to control the tremors.
5th, you go back in to the doctor's office a couple of weeks later. This is where they fine out what your upper limits are. There is a shit load of adjustments. They find out just how much your can stand then back it down enough to control the tremors.
The wifey has been happy with the results. At first, she wasn't. Bunch of second thoughts about having it done. But she is glad that she had it done.
@ShadowsPapa didnt the dealer have to lift the cap of your wife's JL to extract the bolt? I thought that was pretty much SOP on the JT/JL at this point.UPDATE: no good news. Local shop had my truck all day without success. They tried lifting the cab a little but that said there wasn’t enough bolt sticking out to grab on to. Said they’d need to lift the whole cab about 2 feet.
So now what? These are going to be the most expensive rock sliders of all time.
She was nervous the whole time. She was full of questions and second guessing herself about doing it. When she talked to a few people who had it done. That helped her a lot.Oh man, that sounds fun. How did your wife do through that? Docs want to do a full brain map for me as well. But were surprised to find out the x-ray showed 9 screws and some titanium threads flapping in the wind when the last surgery was supposed to remove ALL the hardware and metal. :-/ Hopefully her surgeries were without complications!!
less likely to snap but more likely to round the head off. At least in my experience. Shitty sockets may be more to blame than the impact tho.I'd rather use an impact.
I think it's easier to snap a bolt with a breaker bar than it is an impact.
the JLU was fine - the left front was the toughest of all, took forever on it - heat and try, heat and try, heat and try, but the JLU got done (with help of a forum member/friend doing some of the heavy lifting to save my back)@ShadowsPapa didnt the dealer have to lift the cap of your wife's JL to extract the bolt? I thought that was pretty much SOP on the JT/JL at this point.
Impact isn't your friend on these body bolts. Been down that road too many times in the past, and also thought, what the @#$ - give it a try. Nope. No good.less likely to snap but more likely to round the head off. At least in my experience. Shitty sockets may be more to blame than the impact tho.
I've watched your posts on this with great interest...... you have no idea.She was nervous the whole time. She was full of questions and second guessing herself about doing it. When she talked to a few people who had it done. That helped her a lot.
If your socket is even up to Menards quality, you aren't going to round these big bolt heads. Ain't gonna happen. But an impact will snap the bolt. With a bar you can feel flex in the bolt and use your brain (electrodes or not) to know when to stop. Experience. No way I'd impact these after my experiences (and I tried). In order for an impact to get them loose, you'll be at the "break it off, sucka" setting.
Just do it right - heat, and back and forth with a bar. If an impact wrench was the answer, FCA might have suggested that. You can't get a feel for where the bolt is at with things, or whether or not the locking compound is letting loose or not with an impact, until you have stressed that bolt beyond reuse.
Use what you want, but mine won't see an impact unless I've worked the bolts enough the locking compound is not working. I could use an impact on my JT body bolts now because the locking compound isn't holding and they will easily come loose (with some effort, anyway)
It's one thing to miss stitches, which a doctor I used to go to did in my fingers years ago. A family member who is a teacher of nursing and is in my opinion, the best nurse I've ever met, asked me how my fingers were doing. I said they still hurt like heck and there was still some swelling. She looked and said no wonder, there's still stitches buried down in there (fingers and thumb barely survived a table saw, ER was a joke beyond belief, and doctor didn't seem to know just how bad it was in the end so some things never got reconnected)Oh man, that sounds fun. How did your wife do through that? Docs want to do a full brain map for me as well. But were surprised to find out the x-ray showed 9 screws and some titanium threads flapping in the wind when the last surgery was supposed to remove ALL the hardware and metal. :-/ Hopefully her surgeries were without complications!!
Hence the reason I enjoy this forum so much; every contributing member of this place brings some type of experience or knowledge to this forum. I don't using "contributing" lightly either, they/we/us will provide documentation or data points that prove validity to the point/topic being discussed.Above is proof there's a lot of smart people here.
Same, but if I need to I will buy an induction heater to avoid the collateral damagesOh I'm not touching body bolts if i don't have too. And if I do, they are getting PB blaster over night and then cooked within an inch of bubbling paint or melting the bushing. On the brightside, at least Jeep made sure your body wasn't gonna rip off 20k down the road while on a trail. That body ain't going nowhere.
I have one, it can still heat the bolt up enough that the bolt will transfer heat into any surrounding it has physical contact with and quickly.Same, but if I need to I will buy an induction heater to avoid the collateral damages
Did anyone catch your idea and respond?Would this work?
it is a real problem. Its not just ‘some’. But 9. 9 screws. And some pieces of titanium cord (think of baling wire but titanium not steel).It's one thing to miss stitches, which a doctor I used to go to did in my fingers years ago. A family member who is a teacher of nursing and is in my opinion, the best nurse I've ever met, asked me how my fingers were doing. I said they still hurt like heck and there was still some swelling. She looked and said no wonder, there's still stitches buried down in there (fingers and thumb barely survived a table saw, ER was a joke beyond belief, and doctor didn't seem to know just how bad it was in the end so some things never got reconnected)
Anyway, I can't imagine finding that out after going through surgery of the head to remove all metals then later, oops, guess we missed some.
OMG - I'd be on the other side of unhappy, for sure.
The point of the induction heater is "quickly".I have one, it can still heat the bolt up enough that the bolt will transfer heat into any surrounding it has physical contact with and quickly.
