Instant MPG disappeared from Fuel Economy screen on instrument cluster display.
ChrisNLA
Louisiana
2022 JT Sport Max Tow
I don't have a Tazer. Mine comes and go. Been that way for a year now :CWL:
MikeVeee
2022 Gladiator Mojave
Retired Dentist. Frmr Electrical Engr
Same issue with mine. No Tazer or any other software changes installed. It appears and disappears without any changes to settings from me (I'm the only driver). Been gone from display for several months now. Tried many menus when 1st happened then all on its own 1 day it returned, but several weeks later disappeared again and hasn't returned since. ?‍♂
Before I installed my Tazer. Mine disappeared for months, then one day reappeared by it's self. I installed the Tazer and it's still on.
jonluciano12
Jon Luciano
2022 Jeep Gladiator Mojave
I had this happen once before but it cleared itself up in a day or so, but this time it's been multiple days since the instant MPG disappeared from the current fuel economy page. Instead of showing range below and left of the gage and instant MPG low and right of the gage, it only shows range centered below the gage.
The only variable is I have a Tazer JL Mini installed so I don't know if I've accidentally pressed a button sequence or if there is even a setting to change this.
Anyone ever have this happen and know how to fix?
I had the same issue happened to me and I have the Tazer. After installing the front facing camera and doing a full reboot, it stabilized after a few cycles.
It's not related to tazer or any mods.
I don't have nor have I ever used a tazer, my cluster is 100% stock, I have not installed any camera nor have I modified the radio or anything that connects to it in any way.
All I have done electrically is add a trailer brake controller and use a harness to tap into the 12v outlet power for my snow plow controller.
So the dash and cluster and radio is 100% stock.
While my son was driving the truck, the instant mpg display disappeared.
At first I blamed him for making changes but then when I went left and right with the display, I realized it wasn't him, the display in the cluster had literally changed. The instant was gone and the range had moved down. It's almost like a 3rd display option showed up that you never otherwise normally see as a choice. It was a very different look besides the instant being gone.
Then about 2 weeks later while driving the JT around for errands, I flipped to the other mpg display and then back again (left, then right again on the switch controls) and bam, there it was again, just like normal. It's been fine since then - about a month and a half now.
It took a year for it to go goofy, it stayed goofy a couple of weeks, and then cleared up.
So it's a cluster display thing - it's almost like some never before used option replaces the display we are used to, then swaps back again. Wish I had pictures because other stuff moved as well when it happened.
sns1294
Peoria, IL
2023 JTRD
Press the Right arrow on the steering wheel, toggles my instant mpg on and off
Press the right arrow on my steering wheel, toggles range on and off. There is no instant on either screen since a week ago. This isn't user error not knowing there are two screens. This is a bug in the screens.
In your case, you aren't toggling it on or off, you are completely changing pages of the display - a screen change.
We aren't talking about that - we are talking about the instant part of the display disappearing from that page or screen. Not how to change screens. It simply "disappears" without changing anything.
Until it happens to you and you realize it's not a screen page change or swap, it's hard to understand.
think of it this way - you have a phone with a home screen. Maybe you have the time or the temperature displayed on your phone's home or lock screen.
One day you pick up the phone and that time display is GONE from your home screen. It's just not there. The home screen is still the home screen, but the time display is missing from your home screen.
Maybe you have a computer running Windows. There's a trash can icon on that screen by default.
One day you look at the computer - you've not touched it - and the trash can icon is GONE.
KevinM60
Southern Cal
2023 Gladiator Mojave
CAD/CAM
I’ve had my Glad for 5 months, haven’t done any mods, and my “current MPG” disappeared this week and is nowhere to be found. I’m a techy and still can’t figure it out and from what I’m seeing here it’s something with the software. They don’t show any software update options in the settings, only a version on the “about” page with no date on when it was updated so unless somebody is able to contact the software writers or the IT personnel we may never know the cause.
Mine came back, by itself, a couple of weeks later. I see various time frames, but it normally does come back.
Annoying as heck and an indication they need to check into something, but it doesn't break anything other than take away an expected feature when it does this.
KevinM60
Southern Cal
CAD/CAM
True.
it still shows the green light bar so we have that to show the current mpg we just don’t have the numerical display that makes it easier to calculate.
JTGuy
Pascual
San Dimas CA
20022 Jeep Gladiator
Manager
I have the current MPG in the upper left corner and sometimes on the main screen. I don't know what value it really has in knowing it. What do people use the info for?
KevinM60
Southern Cal
CAD/CAM
My "Current MPG" magically reappeared yesterday with no indication of why.
One reason I know of is, concerning increasing my mileage, is to see how my driving is affecting my mpg. If I can stay off heavy acceleration I get a lot better mileage, which is what i'm after.
It is also kind of amusing to see that number go to almost zero when I jump on the gas. That would be considered entertainment value.
Yeah for sure can be entertaining. It's pretty easy to use it to moderate your driving, plan for hills and so on. I find that I can increase over my normal if I actually plan accordingly on some hills and accept that I'm not going to win a race. My wife used it on her Jeeps and she always had extremely good mpg - whomping the stated mpg numbers on the window sticker every time.
It's sort of like the vacuum gauge of the past - keep the vacuum high and get better mpg.
But you have to do thinking to make it work - plan, not just point and go in a vehicle. So I'm afraid the meaning of it is lost on most of today's drivers.
KevinM60
Southern Cal
CAD/CAM
I’ve learned the main thing for good mileage is to be easy on the gas whenever you can. The Gladiator gas is pretty sensitive.
I learned that with my wife’s Mustang GT.
she was always a floor it and brake it kind of driver but I always just cruised it and looked ahead. It’ll there was a red light I would coast it. When she asked me why I was coasting I would tell her I didn’t see the point of racing to a red light. In SoCal you can also include commuter traffic.
