Lift with no other goal than clearance for deep snow?
IdahoRubicon
Adam
North ID
2021 Gladiator Rubicon Sarge Green
I went through this on my Rubicon.
I ditched the, ok in the snow, 33" Falken AT3W and bought the 35", 10.5" wide Kenda Klever RT and had them studded
My gladiator is now almost unstoppable in the snow.
Of course. Anything studded will perform better than non-studded tires.
IdahoRubicon
Adam
North ID
Thats why I did it.
The Kenda is better than the Falken in the snow even before studding, I don't know if Falken changed the compound, but they aren't as good in the snow as they were years ago.
The Mickey Thompson Baja Boss AT is also substantially better in the snow than the AT3W
Just saying that a lift alone isn't going to help nearly as much in deep snow as going to a taller, better tire.
If you want all-out snow domination, get the factory studded Nokian Hakka LT3 315/70R17.
But OP doesn't want to go to taller tires so he is likely going to be disappointed after dumping money into a lift.
Wheelin98TJ
Devils Lake, MI
2021 Jeep Gladiator
Bean Counter
Thats why I did it.
Studded tires are prohibited in OP's shown location (Minnesota).
We can't use them in Michigan either.
MaximusTX
TX
You don't need a lift you just need these:
Truck Tracks
or these
Mattracks
DJPodratz
DJPodratz
Dave
Duluth, MN
2021 Gladiator Sport
Ok I'm going to chime in before reading everyone else's replies. I have a very similar situation. 2021 sport Willys. We have a very long dirt driveway that I need to drive through very high snow at times. I went one winter before doing anything. Found out all my snow packs up on the axles, especially the front. So I increased tire size from 32" up to 34". Lifts are not worth it if clearance is all you want. Because a lift will not lift the lowest pieces of your jeep. You can go to a skinny tall tire if your looking to retain factory wheel/tire weight. I did a very affordable Teraflex spacer lift to get the nose up a bit for looks.
Long story short I really believe you'll regret going lift kit when your axles still drag on everything.
I am coming to the same conclusion. Thanks everyone for the advice.
