Solidaxle
Ventura Country California
2019 Rubicon
Was going to ask the same thing. What is everybody using the 12 V plug for?
Monte.Trumbull
usa
car
My dealer placed my order this afternoon. Said the same numbers as posted before about 1,440 available and 500 or so called for. We will see...
Wiggy
Downingtown, PA
2020 Rubicon Gladiator
Ordered in February. Was ready to give up. Will believe it when I see it.
WDvl_504
North Carolina
2020 Gladiator Mojave, 2020 JLU Rubi
Retired Infantryman, Contractor, Home School Principal, Counselor, and lunch lady
Ok gentlemen (and ladies if there are any in here), I have a question. Anytime I have hauled anything, it's been small enough, or the tow pig has been big enough, I've never needed a trailer brake controller before. Now, later in life, better jobs, etc...I have a Gladiator Mojave, the wife has a JLU Rubicon. We are planning on a boat, and a small camper. The nomenclature indicates that it is for the Gladiator but is there anything to keep me from installing it on a Wrangler as well?
Sorry if this is an ignorant question, but better to ask and be told no than to try it and waste the money or worse, right? lol
Thanks in advance.
TheClevo
NC
2020 Jeep Gladiator Sport S
Thanks in advance.
Allegedly
https://tfltruck.com/2020/10/the-je...ke-controller-will-also-work-with-a-wrangler/
mpainting
Ohio
I use my 12V for the display unit for the rear camera on my camper. I tried a different cord to plug into the USB-c, but it would not supply power. Planning on running the 12V to the glove box for now since that is the only reason I use the 12V
Squelch
Tokyo, Japan
Toyota Land Cruiser
Military
I use the 12V for an air compressor until I splurge and put in a dedicated system. That will probably go hand-in-hand with when I get the brake controller installed.
SwampNut
Carlos
Peoria AZ
2020 Gladiator Launch Edition
Geek
Thanks in advance.
Nearly all boat trailers have surge brakes, not electric. And all travel trailers have electric. Surge brakes work when they push forward against the truck, all mechanical, nothing electrical. The boat trailers typically have a four-way connector just for lights; TTs have a 7-way.
eaglerugby04
Northern South Carolina
Network Security
Thanks in advance.
How small? The towing capacity of the Wranglers is a pretty low 3500lbs and that is only on the unlimited with 410 Gears.
The biggest issue would probably be the wiring. I don't think the wranglers have a 7 way connector, or the plug under the dash.
SwampNut
Carlos
Peoria AZ
Geek
I looked up the OEM JLU tow package harness and it's a four pin. This means no brakes, no charging line, and no reverse light pin. IE, there's no way the Mopar controller would work, you need to install new wires for those three pins and an aftermarket controller. This is what I had done on both of my JKs. Not a big deal. In fact, having a shop install all that for you is probably only about as expensive as the overpriced Mopar controller.
OMTBiker
Derek
Ohio
'21 JLUR, '21 JLU 80th | Past '20 JTR, '18 JLUR
JLU’s with the factory tow package have a 7 way / 4 way plug and the harness for a brake controller under the dash. My understanding is the controller will work on 2019 and newer JL’s.
PDiddy
Paul
Roseville
Architectural Illustrator
What are people using the 12v plug for? Never used mine nor can think what I would ever use it for.
I use mine to plug in my monitor for my rear camera on my travel trailer. But I’ll find another power solution when the mopar controller comes. I didn’t like the power wire hanging down in front of the dash anyways. I like things look clean. So I’ll probably get a power source up in the tray on the dash.
Solidaxle
2019 Rubicon
2019 JL Rubicon with Tow package. Mopar says controller will fit my vehicle. Part on order.
I wonder if I could route mine up there (dash tray) - all I use it for most of the time is to hold my sunglasses as that lower cubby is a total joke.
