- First Name
- Tim
- Jul 30, 2019
- 19
- 393
- 486
- New Jersey
- 2020 JTR
- #76
So, this sparks a little more discusion. When I removed my oil cooler, the valley didn't seem to have nearly enough oil in it to leak down the back of the block. Unless I missed something, all the gussets would hold the oil in the spaces between them and they would all have to fill up and spill over for the oil to make it to a place where it could leak down the back of the engine. There was some oil there but it could only be described as damp. There weren't puddles of oil present. When I replaced the filter housing/cooler I didn't drain enough coolant so those spaces filled up with coolant that I had to suck out prior to installing the new cooler. Even at that, the coolant never made it down between the engine and transmission.I first replaced the factory installed updated mopar assembly with a Dorman which leaked badly next dat i think it laster a few miles because the area its in looks to hold about a quart before it shows on the ground. Then i said to hell with dorman and ordered a Mopar Which is holding so far according to dip stick as nothing is showing yet. None leaked where the MOPAR upgrade took place always at the bottom. All said and done it cost me $155. For cooler and the cost of new oil. It comes with a filter installed
As I said before, there was no "smoking gun" when I inspected the oil filter housing/cooler after removing it, and I'm pretty sure I replaced a unit that was fine. It's been about 3 months since I first noticed a little oil visible on the bottom of the engine/transmission and during that time I drove cross-country and back and racked up about 3,500 miles. The level on the dipstick never dropped at all, not even a little bit.
That all makes me wonder if I have a weepy rear main seal. It's not enough to even drip to the pavement. I simply noticed the oil stain on the bottom of the engine where it meets the transmission.
