JSPEED
- #16
Absolutely, The factory sub doesn't compare at all.Would you say it was a significant upgrade over the factory subwoofer?
I'm playing around with it this morning getting it all set up and making sure there is no distortion.
I would like to make a note that i did some thinking and don't like the idea of just leaving the rest of the wires just taped up.
So i unwrapped them and decided to connect one set of wires to the left channel of the Kicker HS10 and another set of wires to the right channel.
( GY/BN and DG/BN to the left channel GY/WH and DG/WH to the right channel )
The third set of wires i'm going to put a resistor across them because i do believe if you leave them open they will cause an amplifier code.
My father is the electrical wizard not me and he believes a simple 4 ohm resistor will be fine. So i'm going to try it since i have to wait for a new rear interior panel anyway i have plenty of time to mess around.
As far as connecting those wires i mentioned above to the left and right channels they work great and the sound coming from the HS10 is Great.
The remote wire is plenty long and easily pushed under the interior trim panels without needing to remove them.
