Teraflex bed rail system vs mopar rail system
UnforseenWeather
Jim
Hockeytown
‘21 Mojave
Creative Guy
Much obliged guys! I remember seeing that in the install instructions, now that you mention it.
TeraFlex
TeraFlex
Utah
teraflex.com
JL, JT, JK
Can you use the Teraflex tie down points on the factory Mopar rail system?
Yes. We have the Uinta hocks designed to fit both the factory rails and our rails. As a result, everything that fits and works with the Mopar rail system should be compatible with our rails.
Dave740
Dave
Kitsap, WA
+1 for the Teraflex. I originally bought it because they also sell the tie downs separate, so I could have 6 instead of the 4 that come with the Mopar rails. Since then, they've released some accessories for the mounts. I use the Hi-Lift jack mounts with mine. they mount to the same allen bolts that hold hold the u-hook to the rail mount, and hold the jack 4-6 inches below that so I can still shut my mopar soft tonneau cover and slip my 2x6 cargo divider underneath that. I also saw that they released an antenna mount for it too.
Jeep Gladiator Teraflex bed rail system  vs mopar rail system 1663005702130
Jeep Gladiator Teraflex bed rail system  vs mopar rail system 1663005550326
gladtohave
gladtohave
Ian
Sun City , Ca.
2022 JTRD
Online sales
Thanks for the inputs everyone . Ordered the Teraflex system . 300 bucks and 50 for 2 extra tie points seems like a no brainer but I had to ask inputs and Teraflex won . Thanks again for all that gave opinions .
OPA Mac
2022 Jeep Gladiator
Retired Certified Diagnostic Medical Imaging Services Engineer
If you need channel rails just buy UNISTRUT CHANNEL and CHANNEL NUTS, it,s a lot cheaper.
schnelly
Mark
Wisconsin
2021 Wrangler with a 2021 Gladiator on order
Parts manager
I went with a Mac's Tie Downs set. Very low profile and works very nice with my tonneau cover. Tie dow points are easily removed when not in use.
Trauma PA
Robert
Southwest Florida
24 JT Willys, 20 JL Wrangler, 23 Bronco Wildtrak
Trauma Surgery Physician Assistant
So the factory tie downs will fit your rails then?
Trauma PA
Robert
Southwest Florida
Yes that's what he said ....
Thanks was just seeking confirmation as somewhere I read that the Mopar tie downs do not fit the teraflex uinta rails.
Trauma PA
Robert
Southwest Florida
TeraFlex
TeraFlex
Utah
teraflex.com
JL, JT, JK
The Mopar tie downs can work with our rail system with a slight amount of trimming on the hooks, although it call vary on the age of the hooks. The first and early run of hooks fit directly without any issues; it was a running change on Mopar's end that made the notable exception that a bit of trimming may be needed to fully clear and install them on our rails.
Holy_Crap
Ivan
South Florida
2022 Jeep Gladiator Mojave
I just installed the Teraflex system on my 2022 Mojave, my truck came with the spray in bedliner from the factory and although most of the bolts screwed right in, the last bolt on the front rail driver side must have had a little more bedliner in it because that was the one screw that broke going in:headbang: I went with the Teraflex because of their reputation and their tie down brackets made of metal rather than plastic. I didn't know about the other mounting accessories for this system, I like the HiLift mount since it will be out of the way and under cover during transport.
@TeraFlex, any way to get a couple of replacement 10mm bolts mailed to me? I'm willing to pay for the bolts and the shipping since it was probably my fault the bolt broke.
Jeep Gladiator Teraflex bed rail system  vs mopar rail system 68521890376__F203EB1A-71F8-4801-9F14-EA99219D2D50.fullsizerender
Jeep Gladiator Teraflex bed rail system  vs mopar rail system 68521892919__B5C94935-68BF-43B2-AE37-B0404099410B
CFLgladiator
Orlando
Jeep
Take one of the existing bolts to ace hardware and grab a couple matches
abe57
George
Indiana
2021 Mojave
retired
The bolts are 6mm x 1 ..thats the size of tap I used to clean out the bed liner material .
