Trailer brake controller
Lost1wing
West Georgia
Retired AMT
I use the Echo with a Mercedes ML 350 and Honda Ridgeline. It is great for multiple tow vehicles so I also recommend it. I just installed a Curt Spectrum in the ‘41 Edition Willys we just got because I expect the Gladiator to be our primary tow vehicle. I have not yet towed a trailer with brakes since installing it.
In my opinion, the only drawbacks to the Echo are the need to keep the phone app running to be able to manually apply the trailer brakes and the weight of the unit hanging on the 7-pin connector for long-term use. The rubber strap broke on mine so I use a strip of velcro to support it
installation of the Spectrum is plug-and-play with the correct adapter cable (51526 or 51527) that plugs into the OEM connector located under the dash on the left side. I mounted the main module to the lower dash frame below the steering wheel and the control knob to the plastic panel (see photos attached).
I considered the Jeep OEM controller, but the dealer told me it was backordered with no estimated delivery date and I did not want to remove the 12V outlet.
Curt also has a button that you can connect to apply the brake. No phone needed. The only thing you need to do with your phone would be to select the towing program if you swap it between different trucks . It Curt Echo will remain on the last program used and the panic button will connect to the plug. It works well, but not for technology weak people. I have loaded it out but had to set it up for a few individuals.
GerryAZ
Gerry
Phoenix, AZ
2026 Willys '41 Edition
Electrical Engineer (semi-retired)
As I noted before, the Curt Echo is a good device for multiple tow vehicles. The manual button Curt offers for it still requires the phone for the Bluetooth connection to the Echo, but the Echo application can be running in the background. Without the button, the application must be on the screen to manually apply the trailer brakes. The Echo functions without the application running or Bluetooth connection using its last configuration, but there is no way to manually apply the trailer brakes.
OldGriz
Lanesville, Indiana
Jeep Gladiator Rubicon (JT)
Just Livin'
i run this
https://www.redarcelectronics.com/us/tow-pro-liberty-electric-brake-controller
Tow-Pro Liberty Electric Brake Controller EBRH-ACCNA
Gladiator/Wrangler suitable Tow-Pro Brake Controller Harness (TPH-022) TPH-022
Tow-Pro Mounting Kit EBMK-001
I have question if you don't mind? I had my RedArc Tow Pro Elite installed at my Jeep dealer and it's throwing a flashing red code "...check for suitable wiring on the trailer ground circuit." AND "...There is a voltage drop between the trailer ground and the vehicle ground." Do you have any experience with this code flash?
DylanM
Dylan
'21 JTRD
USAF Retired
@OldGriz
Was the correct vehicle wiring adapter harness used for the install? If yes, I would suspect either a terminal pin got damaged/bent during the install or the wiring connector isn't properly seated.
OldGriz
Lanesville, Indiana
Just Livin'
Thanks, Man!! I’ll check all 3 of those wiring options. Appreciate the input.
GuzziMoto
Skinny part of MD
2023 Jeep Gladiator EcoDiesel
Hopefully they used the correct wiring harness instead of trying to wire it themselves. The unit does include a harness starter that you can then wire up with some effort. But it is going to be far easier and more reliable to use the harness made for the job. With that harness it is plug and play.
Also, if you know someone with a vehicle that is also wired for a brake controller / electric brake trailer you can plug your trailer in to their vehicle to confirm it is not your trailer wiring that is the issue.
JTGuy
Pascual
San Dimas CA
20022 Jeep Gladiator
Manager
Having a 7K tow rating and a factory installed hitch, mirrors and 7 pin plug with no brakes is just not logical to me. Is there any warning on the dash about the absence of brakes? Maybe I am missing something.
