2022 Mojave Diff and xfer case oil?
jayo84
PA
2018 Chevy Silverado
IT
My first jeep and I read conflicting information about LSD and non.
What oil will I need to do both diffs and the xfer case?
Vehicle has 46k miles unknown history.
Thanks!
DiehardTory
Dee
Mid Atlantic
Gladiator Mojave & XJ
Retiree x1 working on x2
The best guidance is in the owner's manual. From our 2021 Mojave manual pg 492
Automatic Transmission – If Equipped
Use only MoparĀ® ZF 8 & 9 Speed ATF Automatic Transmission Fluid or
equivalent. Failure to use the correct fluid may affect the function or
performance of your transmission.
Manual Transmission – If Equipped We recommend you use MoparĀ® ATF+4 Automatic Transmission Fluid.
Transfer Case We recommend you use MoparĀ® ATF+4 Automatic Transmission Fluid.
Front Axle Differential We recommend you use MoparĀ® Gear & Axle Lubricant (SAE 75W85)
(API GL-5).
Rear Axle Differential (M220 Sales Codes DRE/DRF)
(API GL-5). Models equipped with Trac-Lok Limited Slip Differential
require a friction modifier additive.
Brake Master Cylinder We recommend you use MoparĀ® DOT 3 Brake Fluid, SAE J1703.
Power Steering Reservoir We recommend you use MoparĀ® Electric Steering Pump Fluid.
jayo84
PA
IT
Thanks. Sadly the manuals not with the vehicle. Just got it a month ago. With the locker axles we wouldn't have the LSD model correct?
LouisvEarlleJT
2023 JT Willys Earl
Right, the friction additive is due to how the LSD works. The locker doesn’t need that.
jayo84
PA
IT
Does everyone use Mopar? Or should any good synthetic be sufficient?
jayo84
PA
IT
Sorry for sounding dumb. I figured it's easy enough to work on the jeep myself and not pay the shop. I'm seeing 75w90 at the store. I assume that's fine?
smlobx
Eddie
Mid Atlantic
Semi retired consultant
I think most of us that do our own work don’t use Mopar branded fluids. As long as the fluid meets the specs then it’s fine. On my ā€˜20 JTR I used Valvoline fluids for the diffs.
jayo84
PA
IT
That's what I am looking at. The squeeze packs. I assume the 75w90 is good? Can't find 75w85
Most brick and mortar stores will not stock 75W-85. Most people just go to a 75W-90. If you do both front and rear diffs, will need to buy 4 quarts as you will use just a bit less than that. That is assuming you have factory steel diff covers.
Two quarts of ATF+4 fluid will cover the transfer case.
Plenty of Youtube videos showing how to do it. The diff covers have a reusable gasket and if reusing the bolts and not installing new ones, do not exceed 25 ft-lbs of torque or risk snapping the bolts off.
For me, it depends on what the item is. Some things only the MOPAR stuff, but I've done enough differential work over the years, I'm good with a fluid that meets or exceeds the MOPAR specs - gotta be careful, though, with that double-ball pinion bearing. They seem to be more picky, so I used the best I can find.
I have some Valvoline hypoid gear lube in my cabinet.........
jayo84
PA
IT
Thanks for the info!!
I may have made a mistake. I see on the packaging of the Valvoline that the gear oil contains LSD additive. For conventional and LSD diffs. Did I screw up??
They don't seem to offer an oil without it ...
It will work fine. Many of the better fluids work in either.
