Car Wash and OEM Antenna
  • Thread starter Deleted member 24880
  • Start date
  • Watchers 16
Jake
Jake
Charleston,SC
Gladiator Sport
Hey Mark it’s from Craven Speed. See the attached screen shot showing the website and price. Like I said it gets great reception.
Jeep Gladiator Car Wash and OEM Antenna 1F17CC3F-7482-45E7-9033-96D21BCFEF06
Brand? I bought an AntennaX, and it destroyed radio reception (in the middle of Los Angeles). Any recommendations would be appreciated.
Proximo
White Lake, MI
2020 Jeep Gladiator Sport Max
@MarkO I'm 20miles outside of Detroit. I'm using 13" Rydonair and get FM stations very good. Found on Amazon. If you are in the city, should be good
spazzyfry123
Tyler
2020 JTR (Sold) - Now Land Cruiser
ME
Behind the passenger kick panel, right below where the antenna enters the cab, is a grounding point.
I have to say, it was difficult getting in there. Getting the grommet in was the most difficult thing as stupid as it sounds. I could only find one place to mount the box down by the carpet behind the kick panel. Just enough reach to get to the factory antenna plug point.
spazzyfry123
Tyler
ME
Not to keep bugging, but did you ground your CB radio and multiplexor separately? I get great FM reception, but my SWR is at about 2.4 after attempting to tune the CB earlier today. As it sits now I’ve got both my CB and the multiplexor grounded to the same stud in the passenger kick panel. I figure I’ve either got an issue with my ground or possibly need a different antenna. I figure since you’ve had positive results with a similar setup, I’d ask you if you ran into any snags or have any suggestions.
My setup:
Rugged Ridge splitter system and antenna mount
2’ FireStik
Uniden CMX760 CB
khokhonutt
Concord, NC
2020 Jeep Gladiator Sport, 2004 Jeep Wrangler Sport
My setup:
2’ FireStik
Uniden CMX760 CB
It took me a bit to get my SWR dialed in.Here are the steps I took.
  1. I ran a ground wire from the mount itself. I ran a small wire along with the CB wire. The ground wire has a small ring terminal and it grounded on one of the mount screws outside.
  2. That ground wire, the ground for the CB and the ground ground from the multiplexor all ground at the body, inside on a ground lug by the passenger's right foot.
  3. After setting all of those grounds, I checked for continuity to ensure the antenna cable and all of those grounds were good.
  4. My firewire connection only came with a 9' cable. I'd always heard you want 18' of CB wire, so I bought a 9' extension. I've also read you don't want that extra coiled up somewhere, so I ran that cable to the back of the truck and back in one long loop.
  5. For what it's worth, my antenna is the 3' firefly by FireStik. I don't know for sure if that makes a difference since it's my understanding the FireStik antennas are wound in such a way that they are longer reception wise than they are physically. That said, the antenna itself is pretty cheap, so maybe try a 3' and see if it makes a difference. So far I haven't had an issue with mine in parking structures, or going down the road.
I watched several videos on CB SWR tuning. They all said the first thing you want to verify is continuity, so I'd recommend getting a cheap multimeter if you don't already have one and check all of the continuity. Once you eliminate that as an issue, you can focus on antenna length.
All of that said, after much frustration I did find that the SWR can be vary widely if you're adjusting the antenna too much at a time. In the end, after what seemed like 50 trips in and out of the truck, I got my SWR on 1 and 40 at about 1.5. That got my SWR near 0 on channel 19.
I hope all of that helps.
JCJeep1
New Jersey Shore
1997 TJ 37" MT Long Arm 2004 Dodge Ram 2500 Cummins 2020 StingGrey Gladiator Sport S Tow
Old school method of protecting antenna and windshield frame - Cover the whip with shrink tubing or rubber door edge protection (c channel) - removable and adds weight to keep it from whipping around - plus is mar resistant.
spazzyfry123
Tyler
ME
Excellent! Thank you!
BDK
Macomb MI
2020 Jeep Gladiator Overland
I'll second that. Bought the same one on Amazon and live in Macomb MI, just north of Detroit. I actually think it made both the AM and FM better.
Rav34653
Al
Spain
Pinto
I have never used an Automatic or Mechanical car wash on Any of my vehicles cause I have always liked all my vehicle I have owned way to much to intentionally damage them, I Wash at home or at a Wand type Car wash and bring my own wash glove and sponge
fedel01
fedel
New York
Motorcycle
Student
I think automatic Car Wash is not safe for our vehicles. It can damage our OEM Antenna and Other electrical parts of our car. You can follow this guide https://bestobd2scanners.com/car-maintenance-tips/ . You need to take care of your car properly to reduce the maintenance cost!
Thanks for joining the forum to make this post. While I agree that your stock antenna might be damaged in an automatic car wash, your electronics will survive.
Jeep Gladiator Car Wash and OEM Antenna Jeep-Wrangler
My bet - forum spammer............. Been admin'ing forum too many years, pattern is a match.
