Headache rack lighting, will tapping into trailer light plug cause issues?
kb5zcr
2023 Diesel Rubi Gladiator
Howdy all,
I'm welding up a headache rack for my 23 Rubi diesel. I would like to put some aux tail lights in it like the ranch trucks run around here.
I've seen 7-pin "T" adapter harnesses that put a 7-pin trailer connector in the bed of the truck, these are for pulling a 5th wheel trailer.
If I install one of these 7-pin T harnesses on my truck and then tap into that for the headache rack lights, will my bumper 7-pin connector still work when pulling my trailer?
Also, with the headache rack lights wired in this way, will something in the jeep "think" I'm pulling a trailer and change shift points as a towing mode will do.
I guess I could just splice into each tail light wireing and get the headache rack lighting working this way but it would be a lot more work.
I may have to skip the aux taillights in the rack if this turns into to much trouble than I'm willing to put to it.
Any knowledgeable input is appreciated.
Thanks, Tim
JeepOfTheseus
Bay Area
Jeep Gladiator
AFAIK the "towing mode" is just the TCU detecting load, not anything through that harness.
Regarding using a t-tap...as long as the combined draw (if you're towing) remains under the factory fuse rating, you'd be fine.
sarguy1941
Jeep
I use the T adapter as designed on my Back rack for both stop/signal and parking lights. it will work fine. Thruck wont know the difference.
ChrisNLA
Louisiana
2022 JT Sport Max Tow
kb5zcr
Great, thank you for yalls knowledge.
I think I'll continue planning for putting lights in it.
Thanks, Tim
D_JT
Travis
New Mexico
23 JT Rubi diesel, 19 JL Rubi, 00 TJ, 48 CJ2A
kb5zcr
Thanks to all of you for your help. I think I'm going to get a T harness and wire it in that way.
