Heater/defroster temperature control is TERRIBLE...anyone else have the same issue?
SwampNut
Carlos
Peoria AZ
2020 Gladiator Launch Edition
Geek
I just realized I've never used the defrosters, front or back. Do you still have that problem if you hit the dedicated defrost button? I don't actually know what it does.
stingrey
Paul
Ontario, Canada
2020 Rubicon
Civil Eng.
Seems like the OP has a legitimate issue.
I have the cold weather package. If the roof is on, I have the climate control Auto enabled most of the time. The exception is if there's ice in the morning and I use defrost...everythingon Hi.
It works well and seems to provide a steady low fan output to keep the cabin at the set temperature.
If you use Auto, the defrost will be used when the heat is on.
bolingde
North Carolina
2020 Gladitor
Here's an example of what happened two days ago.
The temp outside was around 67, inside the temp (on auto) was at 72. Felt a little cool so I turned the temp up to 74 and it's starts blowing cold air. I waited a few minutes thinking it was blowing the cold air out of the vents but it kept getting colder. Hit the manual button and warm air starts blowing.
Now there is a lot I don't know, and I understand that the system is set up using all sorts of science, but I do know that if you want to get warmer you have to use warmer air not colder.
This means that either mine is broke (which doesn't seem to be the case because others have the same problem) or the gladiator's environmental system is just crap and needs a firmware update or tuning etc.
This was just the last example but it has always functioned about the same way on Auto.
futzin'
Kentucky
Had an issue with mine recently (and I thought I was good to go).
Rolling along gravel roads exploring, outside temp prolly low 50s. Auto Temp set to 71*; all is well.
Rolled down the front windows a bit to enjoy the sounds (which let in the 50* air), and the system proceeds to blow cold air out of the dash vents facing me. Did NOT enjoy that bit of FCA-ness. Turned up the temp a few degrees to no noticeable effect.
Rolled the windows back up . . .
I'll say it's broken.
SwampNut
Carlos
Peoria AZ
Geek
Both of the problem reports above are different from what happens with mine. I've owned my Gladiator for 11 months, where we went from warm weather, to crazy hot, to crazy cold (for AZ). It always works. I've gone out on a 50 degree night with the windows down, and the system automatically starts blasting full hot air from every vent. Honestly it's far more useful and predictable than my 15 JK.
steelponycowboy
Mesa, AZ
2016 JKU Rubicon HR, 2017 Cherokee, 2021 JTR
Retired Peace Officer
Does anyone remember the heater controls on a 60s CJ ;)
Gossamer
Indiana
2020 Jeep Gladiator
Customer Service
I find it impossible to control the heater temperature. Set it to 65, ice cold...69, scalding hot, so hot you are now sweating....back down to 65....still raging hot...63...raging hot....LO....finally goes cold......back to 66....ice cold.....up to 72....getting warmer....73....blazing hot.....back down to 65......still blazing hot. Both sides set at th same temp and different temps coming out of right and left side.
Dealer told me it senses outside air and adjusts accordingly....I'm sorry, but if I set the temp at 66, it shouldn't be blowing 90 degree air and roasting me out of the car.
Anyone know how to fix this, as this isn't normal and the dealer keeps bullshitting us.
I can't say that I've had an issue, and usually just leave it on Auto. However, when my partner in crime (wife) is riding shotgun and must play with the passenger temp, all bets are off and I'm sweating like a moth...., well you know.
SwampNut
Carlos
Peoria AZ
Geek
"Sweating like a moth."
WTF.
Never heard th.......ooooohhhhhhhhhh.
I'm lucky that we're a pretty good match, and it mostly stays in the sync mode.
No dual climate control? ?
Gossamer
Indiana
2020 Jeep Gladiator
Customer Service
thank goodness for dual climate control, but science dictates that hot goes to cold. So, eventually I am too hot, ?
