Rubicon transfer case into Willys EcoDiesel
Trail_Limo_Tim
Vancouver, WA
2021 Gladiator Willys Diesel
I’d like to put a Rubicon 3.0L EcoDiesel transfer case into my 2021 Willys EcoDiesel so I can have 4:1 low range. Can anyone confirm the correct part number for the Rubicon EcoDiesel part time 4WD transfer case? I think it’s
68298660AC
It should be a bolt-in swap, but can anyone else confirm if you’ve done it?
Thanks.
Bandit’s Lair
Southern California
2021 Gladiator Sport S
It’s a direct bolt in. This is provided that they are the same year probably. Not sure if they’ve changed transfer cases over the years. Basically the only thing different should be the guts. The housings should be the same. Both same 23 spline and linkages.
